Quick question, I changed a vram module and managed to lose a 350ohm 0402 resistor. Don't have a direct replacement can a 330ohm be used or can it be left off?
Cheers
Reason: GTX 670
The only boardview i can find for a GTX670 is an Asus board. The layout around the memory looks identical to the Palit I have however the values of the resistors are different. The part I am missing is the one highlighted in Red on the boardview. On the Asus board it is 1.33k Ohm, the part on my board is 350ohm.
Still not sure how critical the 350 ohm resistor is in value. It connects VREFC1 on the module to GND.
You can just try the 330 ohms, if it works them it's OK, but it's probably part of an reference voltage divider as the sigmal name suggests. So could need very exact values.
