Hi All,
Gigabyte 1050TI 4GB, No display volatges present /GV-N105TOC-4D/
Hopefully someone can help me out as I got stuck with this board.
The fault:
Once the card is in a mainboard (tried 3 different motherboard too and flashed 1 of them with all available bios versions to eliminate compatiblty issues).
The fan spins all volatges there, monitor switches on with backlight only after the system being on approx 30-40 seconds and stays like that, if HDD connected you hear the hdd is booting with no issues, no beeps either from mobo and system can be shut down with alt+F4+enter too.
All volatges are present.
12V ok
5V ok
1.8V ok
1V ok
here is the tricky bit, VRM initially there with 1.5V but after a few seconds (when potentially posts in the background) its switches to 1.36V same happens to the main core voltages towards GPU starts with 0.84V and drops to 0.78V.
Everything seems normal after that, GPU gets warm to touch but not excessively, same for all other components. I could not manage to find any shorts so far or open resistors either.
Tried to reflash bios on board and reflowed GPU.
Does anyone have an idea or hint what it could be or which way I should look for?
The fault:
12V ok
5V ok
1.8V ok
1V ok
