UE55KU7000 led active for a short time...!
    I have a mainboard BN94-10832C from UE55KU7000 that have active stand-by led just for 2-3 seconds; no respond at any commands from remote.
    After this time led disappear.
    Backlight is ok, tested without cable from power supply.
    Any ideea...?
    Re: UE55KU7000 led active for a short time...!
    Sounds like the mainboard for sure. Could be the eeprom needs reprogramming. Had a few of the k and m series have this problem with similar symptoms.
      Yes, as for sure need eeprom/flash to write with a good information...
      But i don't have any dump tested for this model.
        See if you can read your eeproms and post the dumps here. There a a few people on this forum that are able to repair them for you.
        Or check eBay. Sometimes you can find eeproms already programmed. It’s better than buying a new board.
          Hi.
          https://disk.yandex.com.tr/d/S7zq8Ir6DAkb8A
          https://www.badcaps.net
            Thank you very much arizanotlari !
            Is possible to have also dump of 24c512 for this model...?
