I am trying to fix an Asus Dual rx5700.
This card has all the correct voltages. It is also recognized when using iGpu.
However when plugged in and BIOS is set to use Gpu for output the computer will hang before post. Error Led stays on the motherboard. Also the fans stop spinning after a while.
I tried reflashing the Bios which did not change anything.
I also tried checking the vrams but so far all I got was initialization errors.
Does anybody have any ideas? Also what would be the correct way to check the memory modules?
Thanks.
Thanks.
