MSI K7T Turbo Limited Edition == version 3 ?
    Hi Everyone,
    I have a MSI K7T Turbo Limited Edition (the one with red
    PCB and Pc2Pc integrated modem) and I suspect to have
    a badcaps board.
    Is my version (Limited Edition) the same one indicated on badcaps.net
    (version 3.0)?
    Igor.
    Here's what the standard KT7 Turbo version 3 contains:
    4 4700uF 6.3v or 10v 12.5mm
    2 3300uF 6.3v or 10v 12.5mm
    2 2200uF 10v 10mm
    9 1000uF 10v *LP 10mm
    Check this list against the caps on your board. More than liekly, they are the same. Double check to be sure. If they're not the same, just let me know what you need and I'll make a kit for you.
    TC
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
