My recently purchased Soyo Dragon2 kt880 v2.0 shows power (LED) and fans spin up on power up but gives no POST or error codes.
I tried many tricks and was able to get the board to give error codes and then POST exactly once, but it returned to its long slumber after rebooting. I am using known good components and tested with two different power supplies (one 300W and one 550W) and bare minimum else installed.
When the board arrived it smells of what I thought might be cat urine (or bad electolyte?). None of the caps are visibly bad, but the smell does seem stronger near the memory slot power area (elc31).
The board was apparently pulled in working condition and stored for a while before I acquired it. I'm not certain if: a) cat urine b) leaking electrolyte c) dried capacitors d) some combination of the above conditions.
I'd like to save the board but I'd like to be certain of the actual problem before continuing. I am decent with an iron and have access to an oscilliscope, but don't have all the equipment I will need.
There are a ton of capacitors on this board all Evercon, all marked T48A.
6) 3300uf - CPU socket
3) 1500ug - main power regulation
19) 1000uf - all over the board
and various other smaller caps...
Here are my questions:
1) Any suggestions on further diagnosing the board *before* recapping are welcome. Checking for ripple, voltage drop, etc.
2) Anyone ever try "washing" a board to remove salts (urine) shorting the PCB. I've read some accounts of mist washing a PCB, but I see that as a very last resort. Any comments?
3) Any caps that probably aren't worth replacing on this board? Especially the 1000uf ones that are all over the place on this board...
4) I don't see this board but once on these forums. Is that because they aren't often bad or just less commonly encountered?
I won't have time to pick this project back up til summer, but I will read all comments, answer questions, and post pictures as requested until then.
Thanks everyone, this site is great.
