motherboard h310-k v20 doesn't display data unless i press restart
    the motherboard from china with this model h310-k v20
    it has an i3-8100 cpu
    and 8 gb of ram ddr4 2400
    built in gpu
    the problem is when i turn on the pc it doesn't show any data unless i press restart button sometimes for multiple times and when it display data it works fine until i turn it off and try to turn it on all over again ... the same problem show up
    1- i've flashed the bios with the latest version
    2- replaced the power supply
    3- tried external gpu
    4- disconnected everything from the motherboard such as HDD USB cable etc..
    any idea ?
    thnaks in advance
    Re: motherboard h310-k v20 doesn't display data unless i press restart
    Sounds like a reset supervisor problem. Do you have schematics for this board?
