Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Thread Tools Display Modes
Old 11-22-2020, 10:22 AM   #1
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
I'm a: Professional Tech
Default Windows XP EoL Security Rollup...or similar?
I've got a customer running some proprietary software (CD mastering software that wont run on anything newer), and is keeping an XP 32 bit system running, and running connected to the internet. It's updated up to SP3...but of course WU doesn't work anymore with XP, it's ancient history.... I was wondering if there was a security rollup around post-EOL that took care of some stuff....even if it's perhaps 'unofficial'....like USP5 was for Win2k....
Bueller? Bueller? Bueller?
__________________
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 11-22-2020, 12:49 PM   #2
R_J
City & State: ☻
My Country: Canada
Default Re: Windows XP EoL Security Rollup...or similar?
Did you check the Microsoft Update Catalog site? Search: (XP sp3) The last critical update I believe was KB4500331
I believe there are unofficial sites that update xp with Xp embedded updates
R_J is offline   Reply With Quote
Old 11-22-2020, 02:02 PM   #3
Fast Alpha
Fast Alpha's Avatar
City & State: Wales
My Country: United Kingdom
I'm a: Knowledge Seeker
Windows Update don't work with XP?
Fast Alpha is offline   Reply With Quote
Old 11-22-2020, 02:10 PM   #4
Topcat
The Boss Stooge
Topcat's Avatar
Quote:
Nope.
Old 11-22-2020, 02:24 PM   #5
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
No they axed it with the introduction of SHA-2 requirements for Windows Update:
https://support.microsoft.com/en-us/...s-discontinued
__________________
Per Hansson is offline   Reply With Quote
Old 11-22-2020, 03:23 PM   #6
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
you can reg-patch to change it to the embedded version.
i'v personally seen so many slot machines running it with blue screens that i wouldnt bother though!!
what is the mastering software?
linux with wine is very good now - and you select the windows version to emulate.
stj is offline   Reply With Quote
Old 11-22-2020, 03:25 PM   #7
petehall347
City & State: worcester
i run old stuff on win 7 in xp mode .also run 7 in developer mode to make things work properly
petehall347 is offline   Reply With Quote
Old 11-22-2020, 04:29 PM   #8
Topcat
The Boss Stooge
Topcat's Avatar
Nero 6.3.1.xx
Won't run on 7 even in compatibility mode....and this guy isn't the most tech savvy.... I got the task of putting it back together on his early P4 system that had a spinner HDD fail. I upgraded it to a SSD with adapters (no SATA)...and of course his requested software is working fine.....but he still insists on web browsing with this thing (uses Opera) rather than leaving it offline and web browsing with something modern...hence checking around for a security rollup post-SP3. On something this slow, I can't even imagine trying to view modern bloatware sites, but I digress.
Old 11-22-2020, 05:54 PM   #9
stj
stj's Avatar
there was an official Nero version for Linux - i may still have it somewhere.
Old 11-22-2020, 06:01 PM   #10
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
all I remember, there was a registry key that one needed to modify / patch after the EOL updates were no more. After that XP updated again. I've got no clue if that patch still works, or if someone else got all these extra updates to be downloaded to a file.
Here is what I was looking for: https://www.zdnet.com/article/regist...or-windows-xp/
CapLeaker is offline   Reply With Quote
Old 11-22-2020, 06:34 PM   #11
sofTest
sofTest's Avatar
City & State: Norway
Well, there are 'unofficial' rollups. Goggle 'Windows XP SP4'. There also are complete installs with all updates slipstreamed into them. One of them are called Windows XP Professional SP3 x86 - Integral Edition.
Have not used them, and don't know if they can be trusted.
Edit: SSD Trim can be a bit tricky on XP.
__________________
Be a mensch
sofTest is offline   Reply With Quote
Old 11-22-2020, 08:41 PM   #12
stj
stj's Avatar
incidentally, nero6 will probably still work with the right aspi drivers
Old 11-24-2020, 01:50 PM   #13
Per Hansson
City & State: ----
My Country: Sweden
Quote:
No it is not tricky at all: it is simply not supported at all
About the embedded fixes: I would assume they also stopped working with the SHA-2 release.
Meaning of course you can do manual install, but no Window Update...
Old 11-24-2020, 03:10 PM   #14
televizora
ghettomodmaster
City & State: Bulgaria
My Country: Bulgaria
Line Voltage: 230VAC 50Hz
I'm a: Student Tech
Why just not replace the Nero and install Windows 7 32bit?
You know that there is more than one way to get it and I don't need to tell you how.
Not that I would not tell directly, but you have DMCA to worry about, not me.
This is closest to SP4 you can get https://www.majorgeeks.com/files/det...nofficial.html
Unless you want to search update.microsoft.com yourself and install manually.
Better give him C2D machine and updated Nero. With 4GB RAM it would be decent for some web browsing.
__________________
Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
televizora is offline   Reply With Quote
Old 11-24-2020, 03:22 PM   #15
sofTest
sofTest's Avatar
Quote:
OS-wise, you are correct. There used to be some SSD-manufacturers that had some trim-like features in their firmware. OCZ (Vertex?) comes to mind for some reason. Don't know if any manufacturers cares about that now days. There also used to be utilities that one could run to perform manual trim, or schedule periodic trim. Don't know if that's around any more either. Hence tricky.
Old 11-24-2020, 03:26 PM   #16
stj
stj's Avatar
Nero 6 is one of the best cd writing softs ever made on windows - and it uses libs that wont run on 7 for several reasons.
too bad they fucked themselves with nero7+ turning into itunes style bloatware!
it also has it's own file format - so if the guy has a big library of images he wont wont to run them through NRG2ISO or similar software.
Old 11-24-2020, 04:16 PM   #17
televizora
ghettomodmaster
I'm a: Student Tech
Softs like ImgDrive support the mounting of NRG images.
Old 11-26-2020, 12:33 AM   #18
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
Hi!
Yes, it's slow to browse modern web on a P4 machine today. At least mine (still main PC) is somewhat newer P4 with Prescott HT CPU (that good ol' Optiplex 170L.)
Anyways, all I can say is... forget about the security rollup. Just make sure his machine is running behind a router that has at least some kind of built-in firewall and doesn't expose the machine's ports to the internet openly. With that and a good hosts file, he shouldn't really have issues, unless he visits tainted websites on a regular basis. But if that's the case, no security update will help that one.
I already have plans to get a newer "main PC" for this year... but likely will still try to stick to XP. There's some crap about Vista and 7 that annoy me to no end when it comes to organizing/sorting files, and I just can't get over it. Otherwise, I've finally warmed up to 7 pretty well now (about time, lol. )
Yeah, I wouldn't trust them.
Genuine XP copy + official SP3 is the way to go.
Old 11-26-2020, 03:33 AM   #19
televizora
ghettomodmaster
I'm a: Student Tech
Quote:
You cant even open a modern page using WindowsXP. Half of the things don't work.
Windows10 is the problem. I use Windows7 with the classic gray theme.
Oh, dear, get something newer. At least dual core Core2Duo.
XP is so ancient now, that most of the newer software will not run on it.
Not that my laptop is that great, but it's at least an i5 with 4 gigs of ram.
The sad thing is that today the web pages themselves had become a benchmark. With all this bloatware.
Windows10 is another story. I had many machines at work with Windows10. Most of them are running Windows7 now.
Windows10 is notorious for it's "bugs" with CPU spiking "Software protection = 50% constant cpu usage"
At one moment, the PC just slows down with high cpu usage and you cant fix it, no matter what you disable.
I will stay with Windows7, even if it's EOL, until they fix this. I cant tolerate constant slowdowns.
Old 11-26-2020, 10:49 PM   #20
momaka
master hoarder
momaka's Avatar
My Country: U.S.A.
Quote:
You can... with the latest/last Firefox ESR (52.9, if I'm not mistaken.) But since that is also rather outdated now, there are indeed a few web pages that don't work correctly. For the most part, though, most websites do still work OK with FF ESR 52.x... maybe not as smooth as modern FF Quantum engine, of course.
That said, the major letdown of using FF ESR (due to Mozilla intentionally blocking FF Quantum engine from installing on XP - bastards!) is that FF ESR (and all pre-Quantum FF really) are not optimized for multi-core CPU, and therefore still perform very sluggishly. The best option is to get a fast dual-core CPU and OC it even more to get higher core speeds, so that way FF ESR runs faster. Of course, P4 architecture, even with its fast clock, is not very efficient, so it's not very good. However, between a very fast Core 2 Duo (like 3 GHz or more) and a much newer CPU, there won't be too much of a difference in performance.
Same.
This applies to both my XP and 7 systems. I also turn off taskbar grouping and many of the other visual [d]effects. IMO, Windows classic is the best and most user-friendly theme that has ever come out in Windows, and I refuse to replace it with anything else.
Oh, I have plenty of newer systems - high-end Core 2 Duo's, Core 2 Quads, Athlon II X4, an i5, and even a dual Xeon octa-core system as of last spring. But the better systems I use for gaming. For everyday use, an Athlon X2 5200+ does the job pretty well and is likely what I will be using (or something along those lines) for my next main PC.
Indeed.
However, aside from Youtube, BCN, email, and a few other select websites, I rarely do much browsing outside of those. So most of the websites I visit don't have a whole lot of bloat (except for YT.) Heck, BCN still runs great on just about anything. If only the rest of the internet was like this place.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
