HP BIOS unlock tool
    Re: HP BIOS unlock tool
    Thanks peste; that worked. Can you tell me what about my original BIOS made it so HPUnlocker didn't work?
    Thanks!
      thanks works perfectly for 840 g3
        Thank you so much for your help sir.
        Yes that file worked perfectly.
        God bless you!
          HP BIOS unlock tool (2)
          Hi all, I have one Elitebook 840 G3 with bios password and I can't remove the password with HPunlocker.
          I need some help!
            Originally posted by viking6791 View Post
            hi all, i have one elitebook 840 g3 with bios password and i can't remove the password with hpunlocker.
            I need some help!
            try
              I need some help!
              Try...
                [/ATTACH]Hi if I could have some help with this 6070B0883401 A01 rev1.01
                  Ghamidi, It works but SSD is locked with Bilocker.
                  Update, I formated SSD and I did a new installation of OS, now it works fine.
                  Thanks!
                    Originally posted by qayyum786 View Post
                    try
                    Don't work now I got message ''Authetication failed''.
                      my read is all FF
                      Do you think the chip is bad?
                        Originally posted by beersandwich View Post
                        my read is all FF
                        Can be , but first verify programmer, connection between programmer and SPI flash if you use wire.
                          Lets Try this. Seem to have an md5 match on two reads. Is anyone able to remove the password for me. I've had to desolder this as the chip is too small to clip on the board.
                            Not to worry, i've figured it out.
                              Ok, so I have read and verified a few dumps and all seems to be working OK. I saved two separate dumps and checked MD5. They matched. The unlocked has a different MD5, this is expected, as the password has been removed? I now have an unlocked file.
                              Should i write straight to IC or use the unprotect erase write and verify option?
                              Thanks in advance
                                Thanks in advance
                                Its enough to erase-write and verify, it is not necessary to unprotect device.
                                  Originally posted by peste View Post
                                  try..
                                  hi friend , i have 840 g6 i tried hpunlocker but dont work ,i have my original ec dump can you help me to unlock it this model its driving me crazy for a week
                                  thanks in advance
                                    thanks in advance
                                    try..
                                      HI friend... I have a HP laptop i tried many bios bin files none of them worked but i got one from here but its not for my laptop model however my laptop is turning on but not working fine. plz help me to get the correct bios bin file. details are as below. Thank you.
                                      Laptop: HP Notebook - 15q-ds0017tu
                                      MB model: EPK50 LA-G07DP. Rev:1.0
                                      Serial number: CND932651D
                                      Product:4ZD80PA
                                        try..
                                        thanks works perfect,i just had to set the board info and all goes like a charm!! you rocks !
                                          hi everyone i am hoping someone can assist me? i have a hp elitebook 850 g1, i have attched a ch341a using the clip method and according to the ch341a it dumped a file from the winbond chip which is still soldered to the board which the size that was dumped is 2,048kb in size. i saved it as biosold.bin and dragged it into the hpunlocker which then created the biosold_unlocked.bin
                                          i then flashed this back to the winbond chip and verified the file which matched but the administrator plus other user names in the bios still remains. what could i be doing wrong? and is there anyone who can help me out?
