HP BIOS unlock tool
    Re: HP BIOS unlock tool
    Originally posted by lapfix View Post
    Try
    I was able to remove the admin password from the dump you sent.
    i did it with utility HPUnlocker.
    I am very glad.
    Many thanks to everyone for their help!
    Unfortunately, the dump provided by Maxpower3 only displayed the logo and did not load further.
      Hi
      The original BIOS BIN file wasn't read properly from us for some reason, so we did it again and verified the one is correct this time. Sorry for your time and thanks again for your help.
      HP Elitebook 840 G6
      Error message:
      "HP Endpoint Security Controller Problem
      There is a problem with the HP Endpoint Security Controller on the unit
      Please contact HP Inc. to have the unit serviced "
        Originally posted by peste View Post
        you have posted the update on the site ... post the backup of the bios
        I apologize, I'm a noob at this. When I try to backup the BIOS, it's requesting the password, which I don't have.
        Any advice? Thank you.
          post the full name and model of the laptop ... which programmer do you use?
            Hi i am new to this i have read what i think i have to do to my Elitebook 850 G5 to reset the bios password with the HP unlocking tool, but I am not sure do I reprogram both chips or just one if just one witch one? Any help is much appreciated.
              for HP 850 G5 post both copies of the 16MB and 32 MB bios chip ... it doesn't work unlocked with HPUnlocker ...
                Cheers I will post when I get them of the board and read them. Am I right in saying these are the chips
                  Hi
                  Can you please help again on my last post regarding the new and correct original BIOS BIN file. Thanks a lot!
                    need help to unlock hp elitebook 840-G7
                      try this ..you still have a 16MB bios chip on the motherboard..make a copy check it with the HxD program and write the 16MB bios chip sent .. look for the 16MB bios chip on both sides of the motherboard ..
                        HP BIOS unlock tool
                        Hi
                        Can you please help on the below:
                        HP Elitebook 840 G6
                        Error message:
                          Originally posted by vk123 View Post
                          Hi
                          HP Elitebook 840 G6
                          Error message:
                          Hi, thanks for your try. But it's still doing the same after reprogramming with your modified BIN file. Can you please advice how to do next?
                          Cheers!
                              after programing this dump
                                enter the DMI information
                                https://www.youtube.com/watch?v=9T57ktw8n3Y
                                  please help me to replace dmi from original dums
                                    I have a HP ZBOOK 15 G3.
                                    BIOS Winbond 25Q128FVSQ chip
                                    Battery, BIOS Battery and Power Supply Disconnected first.
                                    I used the following Programmer: CH314 mini programmer black with the clip.
                                    ASprogrammer 1.4.1 version
                                    Read bios, Verify, use unlocker tool, Erase bios chip, Write unlocked version
                                    Connect power supply & BIOS Battery, after 3 restarts it worked..
                                    Thank you for all the information.
                                      need remove bios password this file. thank you!
                                        Thanks for the unlock tool, but sadly when I turn on the computer after reflashing the bios, I end up with a black screen and the fan spinning to full speed after 15-20 seconds.
                                        I tried to do this twice now.
                                        This in on a HP Elitebook 840 G4. Can someone help out?
                                        I have included both the original .bin as well as the modified .bin in attachment.
                                        Thanks in advance!
                                          Try And Comments
