HP BIOS unlock tool
    Re: HP BIOS unlock tool
    Originally posted by chiangeg View Post
    I bought Ch341A with SOP 8 pin flash clip, but I have few dozens of HP Elitebook 8470P with bios access passwords locked... legally bought from a company but without password because the IT guy that setups the password is unreachable.
    The problem is how do I use 8 pin clip on this bios chip with 16 pins. I have ordered a 16 pin clip and is on the way..but another question arises...how do I connect this 16 pin clip to the Ch341a?
    Thanks for any solution
    I have same problem as yours. How to connect 16pin clip to Ch341a?
    Have you managed to solve this problem, if you did please share.
    I have hp 8570 with password and i want to read the bios and upload it to
    forum so somebody can unlock it. hp 8570 has 16 pin bios chip and i dont know how to read it. i have managed to read 8pin chip with ch341 but i am
    stuck with 16pin chip. I am asking other forum members as well to help me out with this problem.Please share your knowledge. Thanks
      Google for pinout and match it with soic8 pinout. They have those same 8 pins.
        The chip with no scratches is not original, bought on ebay, and caps lock blinks 7 times with it. Is it because the numbers arent the same? The scratched one has a password and boots fine
          The chip is exactly the same, so if you have problems, check the soldering (try to resolder the chip), or simply the chip is not programmed correctly.
          Become a Badcaps supporter
          Thanks to all supporters.​
            Compare the picture on the left where the chip is on the pads, and lined up with the white silkscreen line on the left. Now compare to the second picture,the chip is too far to the right and too far up, by over a milimetre or two
              I got the Probook 4520S laptop locked. Attached my dump file.
              Anyone can help to do the unlock?
              Thanks.
                Thanks.
                the copy of the bios you posted is empty, try again and post again.
                  Hi i need bios and unlock procedure for a Hp Zbook g3 Studio motherboard 80D4.
                  thx in advance
                  ciao
                    Hi - how do I unlock BIOS for HP 840 g3 laptop? Please help & many thanks!!
                    Sorry!! HP EliteBook 840 G6!! not G3
                      I already erased and blanked the bios : (
                      If i used other user's dump file from this thread, will it help?
                      Thanks.
                        Originally posted by Vesko356 View Post
                        No, just upload the files here and someone will do the unlock for you.
                        please help me pass bios
                        Last edited by SMDFlea; 10-03-2021, 06:20 AM. Reason: bios removed, posted 3 damn times already
                            wasting your time https://www.badcaps.net/forum/showthread.php?p=1074945
                              hi guys!
                              i have laptop hp zbook 15
                              display showing "security device problem "
                              every body can help me fix?
                              thank you so much!
                              all donations are welcome,
                              >>>>> click on this link to donate via PayPal. <<<<<
                                Hi Everyone.
                                I have an Elitebook 840 g2 with BIOS Admin Password. Please! I need help in unlocking it.
                                Thank you.
                                  Originally posted by classicandy View Post
                                  Hi Everyone.
                                  Thank you.
                                  Havn`t you tried the HPUnlocker and/or the RCUnlocker tools from the first post in this thread ?
                                    No, I haven't. The last time I tried using HPUnlocker, I wasn't successful. I guess I don't know how to use it correctly.
                                      I am trying the RCUnlocker currently. Will post results. Thanks
                                        I have successfully unlocked it using the RCUnlocker tool. Thanks for your assistance.
                                          Originally posted by clrscr View Post
                                          hi guys!
                                          thank you so much!
                                          please help me !!!!!
