Dell Optiplex 5080 micro BIOS lock
    Hey, does anyone have a solution for this?
    bios password and computrace(absolute) are enabled.
    FXWQD93 8FC8
    Re: Dell Optiplex 5080 micro BIOS lock
    FXWQD93 8FC8
    @soti
    I will help you,
    post a new dump, before the new reading disconnect all batteries including the CMOS.
      Originally posted by mirbytes View Post
      @soti
      I will help you,
      can you explain what you mean? I desoldered flash of the board before reading.
        Ok so I replaced the bios region of the file (second half) with an "empty" one which I pulled from a DELL bios update package (used older version, same as mine).
        Booted and password/computrace/express tag are STILL there!
        I cannot find a second flash on the motherboard, I looked many times.
        Do I also also have to clear ME region? I found the express tag in there but could ME also hold bios pass? Doesnt make sense
          Solved!
          Ok I did it...
          I didn't have to clear ME, I just removed a chunk of data from the EC region manually.
          If anyone needs help with this model, reply here.
            Re: Solved!
            Ok I did it...
            hello, i need this bios because it's locked and have a password
            i need clear one please
              Re: Solved!
              can you pull your bios dump and post it?
                Please help Bios Password
                  Try and let me know.
                    Hello!!
                    Help this file
                    Does it work in Dell optiplex 5080SFF PC?
                    Thank you for your help
                      Originally posted by kuszkusz View Post
                      Hello!!
                      Help this file
                      No ,It's a micro, if you want a new file you have to post your bios file here (even if the bios is broken) with the service tag number.
                      Become a Badcaps supporter
                      Thanks to all supporters.
