HP 14-dq 14s-dq DA0PADMB8F0 REV:F
    I have HP 14-dq1040wm DA0PADMB8F0 REV:F with black screen. I need some help with this bios. I need bios.
    And old bios is attached
    Re: HP 14-dq1040wm DA0PADMB8F0 REV:F
    you do not have the original bios ?? this bios has been configured before ..
      This is the bios (orginal) with black screen. I didn't have any other working bios.
      It is just backup bin file
        Still I am waiting.
          Still I am waiting.
          Post the serial number on the case
            sir SMDFLea i have the same unit . The problem is it power indicator lits up few seconds only then shuts off . here is my serial S/N :5cd9433hyx
              Sir i need your help
                still i am waiting.
                Become a Badcaps supporter
                Thanks to all supporters.
                  Originally posted by hoaca388 View Post
                  Hi brother . will it work on my unit ? my model number is 14s-DQ1037TU
                    I downloaded this dump from an HP 14-dq1040wm that doesn't work at power-on due to a short in one of the power lines, I'm not sure if it's working
                      [[/php][/php]
                      i have hp 14-dq1040wm da0padmb8f0 rev:f with black screen. I need some help with this bios. I need bios.
                        HP 14s-dq series turn on and off loop
                        Hi i have a HP 14s-dq2013ns S/N: 5CD127GRLV DA0PADMB8F0 REV : F
                        Laptop start and shuts off after 1-2 seconds i think maybe BIOS is corrupted, can anone check my dump and clean it please ? here i post original dump
                          Re: HP 14s-dq series turn on and off loop
                          https://www.badcaps.net/forum/showthread.php?t=103526
                          6. Finding bios update packages
                          6.1.8 HP
                          See:
                          [Guide] How to extract ready for programming dump from HP update executable file
                          https://www.badcaps.net/forum/showthread.php?t=121948
                          https://www.badcaps.net/forum/showth...51#post1261151
                          When you`ve found and extracted the right bios using the guides above you can add the DMI (serial number,featurebyte etc) and Windows key to the new bios using following offsets
                          DMI: 801000 - 8020FF
                          Win key: 886000 - 88603F
                          Thanks to all supporters.​
                            Re: HP 14-dq 14s-dq DA0PADMB8F0 REV:F
                            try this, is ok
                              this main bios works without DMI data. just flash directly.
                              give feedback.
                                HP 14-dq 14s-dq DA0PADMB8F0 REV:F I need someone to help me to remove password please!
                                Hello, I have a hp 14-dq 1040wm. It turns on and the numlock flashes 5 times. then 3 quick ones. The equipment has already been reprogrammed, the bios, I don't know if it is the original. Leave a copy and label of the model. The plate made is da0padmb8f0 rev f Model: 0PAD.
                                thank you.
                                  thank you.
                                  RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                                  https://www.badcaps.net/forum/troubl...before-posting
                                  You MUST:
                                  • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                                    this is my serial and model .. and original bios
                                    • Vesko356
                                      Vesko356 commented
                                      Editing a comment
                                      Read the rules before posting
                                      You MUST:
                                    HP 14-dq 14s-dq DA0PADMB8F0 REV:F Model 14-dq1039wm Serial: 5CD941HGX4 BIOS DUMP Original Width Password , Please Help me to remove THanks
