Has anyone used this product before / is this real or BS claims
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
All of the mosfet that are taken out by bad capsTags: None
Re: Has anyone used this product before / is this real or BS claims
1) Any website that continually spams me with "xyz just bought 4, order now" already has me suspicious.
2) Yes, ISPs likely give you the cheapest possible router. However, I don't believe for 1 second that "a cheap router that gets slower over time."
3) Poor grammar also raises red flags. For example, "Thanks to brilliant engineer"
4) Stay away is my advice.
If you have problems with wifi in your enviroment, starting by troubleshooting, doing a wifi site survey, etc, etc.--- begin sig file ---
--- end sig file ---
Ok
I thought it was BS
Thanks for confirming this for me
It was an advertisement on a music videos on YouTube not something that I got emails aboutLast edited by sam_sam_sam; 01-30-2021, 01:41 PM.9 PC LCD Monitor
1 Dell Mother Board
Originally posted by sam_sam_sam View PostIt was an advertisement on a music videos on YouTube not something that I got emails about
If you are watching on Android, I suggest newpipe or youtube vanced. Both will block ads.--- begin sig file ---
All the above is what I personally use and all 3 are open source.
https://github.com/YTVanced
https://github.com/TeamNewPipe/NewPipe
https://github.com/gorhill/uBlock--- begin sig file ---
And I forgot the most important point in my initial reply.
5)--- begin sig file ---
Originally posted by retiredcaps View PostAll the above is what I personally use and all 3 are open source.
Look in the application store for ad blocker ( free version but I might upgrade to the pro version later after I have used for a while ) but you do have to use safari for it work correctly which I have just started using it and it works pretty good the videos do not get interruptLast edited by sam_sam_sam; 01-30-2021, 07:26 PM.9 PC LCD Monitor
1 Dell Mother Board
3) Poor grammar also raises red flags. For example, "Thanks to brilliant engineer"ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
16 GB AData XPG Spectrix D41
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
