acer aspire 4752 JE40 HR MB 10267-4 no power
    hi guys
    just want to know what you thinkk about this and if a replacement is needed
    thanks in advance
    its an acer 4752 no power liquid spilled
    3.3v/5v power ic
    rt8223mgqw-gp-u1
    pin
    1=1.17v
    2=0.02
    3=1.98
    4=1.98
    5=1.26
    6=1.26
    7=0.28
    8=3.37
    9=4..6
    10=0.28
    11=0.28
    12=0.0
    13=2.71
    14=3.38
    15=0.0
    16=19.31
    17=5.01
    18=3.35
    19=0.0
    20=0.06
    21=0.06
    22=4.59
    23=3.32
    24=0.06
    attached is the picture of the ic
    and schematics
    thanks
    Re: acer aspire 4752 JE40 HR MB 10267-4 no power
    check voltage on power switch and battery tarmenal
      looks like the chip has 3.3v_aux on pin 8 and 5v_aux on pin 17
      and you have on pin 18: 3.35v for enable
      but no 3.3v_pwr and 5v_pwr output
      so you need to replace the chip if you don't have any external shorts
        on what pins?
        the right side!
        Pins 7 and 24?
          3.3v_pwr should be on pin 7 and 11
          5v_pwr should be on pin 20 and 24
          also both images sides are identic except that enc pin 18
          here is the schematic without password .
            check all pins on 3 or 4 you get 3v and also check voltages on bios chip
              both 3 and 4 pins are connected to vref which is generated internal in rt8223b
              and is 2v (check the datasheet) also he can't have voltage on bios because 3d3v_pwr on pin 7 must be ok.
              crazypepe try new chip rt8223b
                You need to replace this chip.
                  have problem to with 4752 ..
                  power on normal with battery ..without battery is no response power on
                  charging can only do in windows (laptop already on with batt)
                  charging in non power on laptop, charge led on then off,power button press nothing happen, remove charger, remove batt, install batt ..power on normaly
                  could be thic power ic broke?
                    for me to be fast in trouble shooting replace the power ic then check again....
                    the voltage....
                      nyimax
                        is it same 10267-1 and 10267-4 ?
                          nyimak aku
                            Originally posted by gamel Expert77 View Post
                            nyimak aku
                            apanya sing di simak.. hehe
                              RT8223A is compatible with TPS 51125A which is more common, try replacing it
                                i have the same model of unit but my problem is that the mobo cant detect hdd and odd.,i check the power supply for the hdd and i read it only 3v..,can someone help me on this problem..
                                  Pin 8 and pin 17 are 3.3v& 5v VEGR check
                                    thank u
                                      change ptc4102,ptc4101 it willbe work
