Need Schematic or Boardview HP 1000-1b09AU
    The problem with this mainboard, when using battery source it's shutdown after 1-2 second but it works on adaptor and charging battery normally. After shutdown using only battery power source, when it turned on again the bios displayed warning something about the "temperature shutdown".
    I attached pictures on the mainboard and the casing of notebook
    Re: Need Schematic or Boardview HP 1000-1b09AU
    anyone?
    please...
      Unfortunately for you, there is no schematic available for your Motherboard as of today.
      If system works fine on AC adapter but power off 1 - 2 seconds after removing the adapter, the primary suspect should be the Battery pack. Have you tried another Battery ?
