Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 11-18-2021, 08:27 PM   #1
mgrharry
City & State: los angeles, ca
My Country: usa
I'm a: Knowledge Seeker
Default Fanatec Wheel Base PCB Eyelet Replacement?
Working on a Fanatec wheel base assembly with a damaged USB port. It has a USB B female USB port (like a printer). One of the traces underneath the USB port as torn, and the PCB eyelet is damaged. The torn trace itself is not to big a deal to fix, but the eyelet is another matter. It's the eyelet for one of the smaller USB data pins, is it possible to find a replacement eyelet somewhere? Where can I order something like that? And what tool would I need to crimp it in place?
Thanks.
mgrharry is offline   Reply With Quote
Old 11-18-2021, 08:42 PM   #2
mgrharry
My Country: usa
Default Re: Fanatec Wheel Base PCB Eyelet Replacement?
Mouser maybe for eyelet, I guess I can measure size of original eyelet with caliper. Although it seems they only have brass eyelets, not copper.
https://www.mouser.com/c/electromech...q=pcb%20eyelet
There's also https://www.circuitmedic.com/index.html
Prices seem high but perhaps a better selection than mouser.
Any recommendations on eyelet setting tool for this small size?
Old 11-19-2021, 04:55 AM   #3
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
the board doesnt have islets, it's through-hole plating.
if you can see where the pin connects then run a jumpwire, if not because it runs inside the board then you have some work to do
stj is offline   Reply With Quote
Old 11-19-2021, 03:59 PM   #4
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
jb weld it. just make sure all the connections are made properly.
CapLeaker is offline   Reply With Quote
Old 11-19-2021, 04:18 PM   #5
stj
stj's Avatar
so jb is non-conductive??
i thought it was "metal loaded epoxy" ??
Old 11-19-2021, 06:27 PM   #6
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
JB weld makes all kinds of epoxy including non conductive. I use it to fill in holes in boards all the time. I just find this JB weld is better than LePage. Preference I guess.
Old 11-21-2021, 02:25 PM   #7
sam_sam_sam
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
Quote:
Which JB weld do you use on circuit boards I have need to fill holes before
__________________
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 11-21-2021, 05:00 PM   #8
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Quote:
Not sure on top of my head but it's something called like Clearweld. It dries clear like any other clear epoxy.
Old 11-21-2021, 08:09 PM   #9
sam_sam_sam
My Country: USA
Thanks for the information
Old 11-19-2021, 08:23 PM   #10
R_J
City & State: ☻
My Country: Canada
I don't think he is trying to fill a hole, the hole which had a feed-thru is where the usb pin is located, he just needs to connect a thin wire between the usb pin and where the trace went.
R_J is offline   Reply With Quote
Old 11-22-2021, 07:15 PM   #11
mgrharry
My Country: usa
Eyelets are tiny, 1mm hole width and 1.5mm flange head. Only place that seemed to have it was CircuitMedic. The refill kit here should do the trick:
https://www.circuitmedic.com/products/201-3140.html
Old 11-22-2021, 07:28 PM   #12
petehall347
City & State: worcester
My Country: United Kingdom
i normally put a strand of wire through the hole and call it done .. has to carry enough current though .
petehall347 is offline   Reply With Quote
Old 11-23-2021, 08:55 AM   #13
sam_sam_sam
My Country: USA
Or another option is to take wrapping wire and rap around the compost pin and make a pad where is none left I have done this yes it takes some patience and a little bit of trial and error for you to get it right
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
