Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 11-02-2021, 11:01 AM   #1
Bloopeta
City & State: Hartlepool
My Country: United Kingdom
I'm a: Knowledge Seeker
Default DMHC DC Motor Controller for Electric Quad
Hi, I was given a Funbikes 96 36v 800w Electric Quad.
Problem is the guy who had it connected the batteries wrong. It has 3 12v batteries in series, but he connected the 3 batteries in a complete circuit (diagram attached to explain, please excuse my drawing lol) and connected them to the quad, and said the motor controller made a fizzing noise and smoked lol.
Funbikes no longer stock a replacement controller, and I am unable to locate one online with the part number.
I opened up the controller, and immediately could see some blown caps, so I have replaced all the caps, however it still does not seem to work.
I am litterally clueless where to even begin with this, so any help and advice greatly appreciated.
Bloopeta is offline   Reply With Quote
Old 11-02-2021, 11:19 AM   #2
petehall347
City & State: worcester
Default Re: DMHC DC Motor Controller for Electric Quad
he most likely connected it backwards .
petehall347 is offline   Reply With Quote
Old 11-02-2021, 12:12 PM   #3
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Shorting out the batteries like drawn will protect the controller and should not fry it. The batteries will take the brunt of the damage in this case -- but as petehall347 says, this is not what happened. It was reverse connected, sparks flew, capacitors exploded, silicon melted.
Likely all semiconductors like the controller succumbed to the backwards voltage. So past the capacitors, the controller probably melted. The switching transistors may have survived, don't know but you may have to replace them too.
eccerr0r is offline   Reply With Quote
Old 11-02-2021, 01:13 PM   #4
Bloopeta
The most annoying part is im strugging to plug the controller back up, as was unplugged when I got it, so am having difficulty working out what plugs go where as alot are the same, however the colours of the wires on the controller dont match up to the colours of the wires on the quad :/
Looking at the board I can see initials where wires are connected, i.e. GND, but struggling to work out what the others mean
SL
SB
GS
KEY (ignition)
GND (ground
But dont know what these are
SL (3 wires go to this one)
SB
GS
DS
+5V
Old 11-02-2021, 03:44 PM   #5
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
not enough to go by for someone who's only familiar of the general structure of such control boxes - can assume fat wires goto the motor or battery and thin wires to the throttle and brake controls... past that, you need to scrutinize the board to figure out what goes to what.
TBH it might be easier to just buy another generic controller and replace the burned one.
Old 11-02-2021, 04:00 PM   #6
Bloopeta
I seem to have worked out where the wires all go now.
I get power to ignition switch, and to forward/reverse/off switch, and the horn works lol.
But apart from that, I havnt got it to move yet.
One battery seems pretty shot, im only getting a total of 28v, but would assume it should still work with that but underpowered/slow??
I have emailed the company who makes the controller to see if they can advise where to get one, but if not I think n new generic one may be the only option if I can get one thats compatible. Just depends on the cost, as may not be viable, especially if need a replacement battery also. Plus, due to contoller problem Im not even sure the motor is good.
Just seems a shame to scrap it
Old 11-02-2021, 04:20 PM   #7
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
There should be a voltage regulator ic on the board, likely that to220 near the caps, If the voltage was reversed and blew the caps it may have damaged the input to the regulator ic and if that is the case it may have protected the rest of the circuit, so check the number on the to220 parts to see if one is indeed a low voltage regulator and check its output voltage
R_J is offline   Reply With Quote
Old 11-02-2021, 04:22 PM   #8
petehall347
charge batteries separately
Old 11-02-2021, 04:26 PM   #9
Bloopeta
Quote:
I am with a car battery charger, one battery doesnt seen to want to charge past aprox 7 volts, and holds around 5.49v standby
Old 11-02-2021, 04:31 PM   #10
Bloopeta
Quote:
Which is that please?
Old 11-02-2021, 04:45 PM   #11
R_J
City & State: ☻
My Country: Canada
Quote:
It might be this one, post the number that is printed on it. Also post the number of that ic next to it, that might help with what voltage the circuit needs. Likely around 5vdc
Old 11-02-2021, 04:58 PM   #12
Bloopeta
Quote:
Originally Posted by r_j View Post
it might be this one, post the number that is printed on it. Also post the number of that ic next to it, that might help with what voltage the circuit needs. Likely around 5vdc
lm317t
g4091 vw
chn 321
Old 11-02-2021, 05:00 PM   #13
petehall347
https://uk.farnell.com/stmicroelectr...317/dp/9756027
Old 11-02-2021, 05:25 PM   #14
R_J
City & State: ☻
My Country: Canada
Oh Great, an adjustable LM317t, You should be able to check its output voltage between the metal tab and ground
Old 11-02-2021, 05:36 PM   #15
Bloopeta
Ive ordered one
Old 11-02-2021, 05:37 PM   #16
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
A "good" AGM SLA will charge back up if discharged completely and recharged right away, you probably have bad or worn out SLA packs and probably need to replace those, too. If you don't recharge right away, you increase the chance of it becoming unrechargeable fairly quickly -- I wonder how long the battery sat discharged.
Note that one dead battery can kill the whole pack making the vehicle unusable, especially if the controller detects battery issues. I have a 24V ⅓HP scooter, battery pack is shot. Powers up, no motion despite still being close to 24V. It droops below 24V for a moment when the motor starts and the controller will stop trying to power the motor before the voltage goes any lower.
Old 11-02-2021, 05:37 PM   #17
Bloopeta
I had to remove it from board to read the number, so will just replace now with new one
Old 11-03-2021, 09:27 AM   #18
Bloopeta
Think I best get a new battery, as one is only holding 6v at best.
Not sure how long they were left discharged, but I suspect it was quite a while
Old 11-09-2021, 05:19 AM   #19
Bloopeta
Just to update, it arrived today, installed that, and have a replacement battery for the bad one, and still not working
Old 11-09-2021, 12:46 PM   #20
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
My Country: USA
Well you'll have to go and test each device on the board and see if any are dead. Not enough data here for us to really give any additional suggestions at this point, picture angles are insufficient.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
