LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Originally posted by malakas1 View Post
    Hello, i am new here. This is a great support board, thanks to all participating.
    I have general question.
    How does it work?
    I bought ch341a usb eeprom reader.
    Do i have to make a backup of my bricked or locked bios with ASprogrammer tool and post it here to get new unlocked bios, or can i use an already unlocked one from one of the postings here?
    my laptop is a yoga x1 2nd gen.
    thank you in advance.
    regards
    You need to make 2 copies of your locked BIOS. Compare them in HxD so that they are the same.
    Then follow the instructions
    [ HOW TO USE THE PATCH ]
    STEP 1: Flash and replace current BIOS with the generated patch file
    STEP 2: Boot the machine
    STEP 3: Press ENTER/F1/etc. to enter BIOS settings
    STEP 4: Enter any character when asked for Supervisor Password
    STEP 5: Press enter when it shows Hardware ID
    STEP 6: Press space bar 2x when asked
    STEP 7: Turn off machine
    STEP 8: Restore original BIOS
    STEP 9: Reset BIOS settings to factory default
    [ NOTES ]
    When booting the patched BIOS you might have to:
    - Hold the anti-tamper switch down the whole time (use tape)
    - Remove the hard disk or replace it with a locked one
      Thanks, it worked!!!
        Is this my Bios Chip?
          @malakas1
          That’s your ThinkPad BIOS chip, made by Macronix (MX), it’s a CMOS type chip which is susceptible to Electro Static Discharges (ESD).
            good afternoon, help patch Lenovo L460
              can somebody please patch the file for me , it lenovo L580.
              Regards
                please can somebody help me to patch and clean my bios from Lenovo X1 Carbon?
                  Regards
                  https://www.badcaps.net/forum/showthread.php?t=76035 .The NM-B461 has an ITE EC ,so the patcher won`t work
                    What generation is it ? ,some older ones have the p24s08 chip .
                      Thanks.
                        Its 3 generation with proccesor i7 5th generation.
                        Main:LMQ-2 MB.13268-1 448.01406.0011
                          https://www.badcaps.net/forum/showpo...0&postcount=11
                            I will try it tomorrow and i will let you now.
                            Thank you.
                              It works perfect.
                              Thank you very much!
                                Try
                                  lenovo se2
                                    Lenovo L480 can supervisor password be removed?
                                      lenovo e445 has bios password plz unlock
                                        Can someone pls remove the admin password from this dump?
                                        Its a Lenovo 510-22ish F0CB machine.
                                        Thanks in advance
                                          @Berlino
                                          You should probably have open a new thread, but here's your file cleaned anyway. This bios uses AMITSESetup UEFI var, tried to recover actual password but seems to be using a different encoding, so I just patched the variable.
