Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 08-17-2019, 04:10 AM   #1
Nix125
City & State: Swindon
My Country: Uk
I'm a: Knowledge Seeker
Default Samsung UE55H6200 Sound but no video display
Good morning all hope someone can help,
One evening a week ago Our samsung TV screen suddenly went blank but audio was still working. Left for a while then turn off/on power to see it this resolved the issue but issue still persists. Input is not the issue as menu screen is not visible either. Did the flashlight test which failed also. Audio still works but no led back light or video display.
Please see attachment for picture of the tcon, power board and main board. Before I start randomly changing boards, ect. When powering up the front red LED flashes around 7 times. Can anyone advise on how and what to test next?
Kind regards
Nix125 is offline   Reply With Quote
Old 08-17-2019, 04:14 AM   #2
nomoresonys
City & State: midwest
My Country: U.S.
Default Re: Samsung UE55H6200 Sound but no video display
With tv unplugged, unhook cable from powerboard to mainboard, plug tv back into power, see if backlights come on.
nomoresonys is online now   Reply With Quote
Old 08-17-2019, 04:38 AM   #3
Nix125
My Country: Uk
Thanks for the response nomoresonys as soon as I get home I willteat
Thank you
Old 08-17-2019, 07:32 AM   #4
Nix125
My Country: Uk
Ok so when I disconnect the power board from the main board I can see the LEDs light up from the holes behind. Coincidentally it seems that if I keep the power connect to the main board and disconnect the tcon board the LEDs do light up. What can you make from this?
Kind regards
Old 08-17-2019, 08:14 AM   #5
neilc6
City & State: BC
My Country: Canada
Disconnect ribbon cables (unplugged) one at a time and see if you get a picture.
https://www.badcaps.net/forum/showthread.php?t=50646
neilc6 is offline   Reply With Quote
Old 08-17-2019, 08:29 AM   #6
Nix125
My Country: Uk
Hi neilc6, I've tried disconnecting the ribbon cables one at a time and have the same issue. It seems that as soon as the t con board is connected the leds go out even with no ribbons connected to the LCDs. There are no lights built onto the tcon board. Could it be a faulty tcon board?
Old 08-17-2019, 08:38 AM   #7
nomoresonys
My Country: U.S.
It is looking like a faulty tcon, I would try one if they're not to expensive, tcon can be tested, how to test can be confusing tho if not clearly marked.
Old 08-17-2019, 08:42 AM   #8
Nix125
My Country: Uk
Thanks for the reply do you have any guidence on how to test?
Old 08-17-2019, 08:56 AM   #9
nomoresonys
My Country: U.S.
To be honest I have trouble knowing what the voltages should be, haven't had to deal with them very often, well lets see which one you have, what are the first 10 letter/numbers on your white sticker? Should start with bn-96xxx.
Old 08-17-2019, 09:04 AM   #10
Nix125
My Country: Uk
Thanks for looking nomoresonys. Take a look at my attachment you should be able to zoom up as its decent resolution?
Old 08-17-2019, 09:33 AM   #11
nomoresonys
My Country: U.S.
See the labels vgb 14, vgb13 etc, and the little round copper looking pads, there's like 28 or so, those are test points but I don't know what voltage they should be.
Old 08-17-2019, 10:36 AM   #12
nomoresonys
My Country: U.S.
One there that seems to be a match: https://www.ebay.co.uk/itm/5555T10C0...UAAOSw2QtdJ2za
Old 08-17-2019, 10:49 AM   #13
nomoresonys
My Country: U.S.
Just in case it can't be fixed, list there, the first one has a bit different numbers think I would skip that one, but from 2 down a ways look like a match, they seem to have a bunch of them, they also have a make offer option: https://www.ebay.co.uk/sch/i.html?_f...vn05.7&_sop=15
Old 08-17-2019, 03:02 PM   #14
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
https://www.badcaps.net/forum/attach...2&d=1566036467
Check: with and without ribbon cables between the LCD panel connected. Do not disconnect and re-connect any cables when TV is plugged into the outlet.
VGH
VCOM
V12
Does LED3_AVDD light up when TV is turned on?
__________________
budm is offline   Reply With Quote
Old 08-18-2019, 12:11 AM   #15
Nix125
My Country: Uk
Hi nomoresonys thanks for the links on ebay I checked them out a few days ago hopefully tcon board will fix the issue. Dudm we tried with and without the lcd connect which made no difference. There is no led on the tcon board?
Many thanks
Old 08-18-2019, 06:06 AM   #16
nomoresonys
My Country: U.S.
Did you test those three spots in Buds post #14? VGH
VCOM
V12
Old 08-18-2019, 06:45 AM   #17
Nix125
My Country: Uk
Hey nomoresonys I can see VGHC, VGL and VGB12 on the TCOM board is this the pads to check. I have a multimeter what am I checking for? Thanks
Old 08-18-2019, 09:28 AM   #18
nomoresonys
My Country: U.S.
Damn if I know, I was trying to learn what they should read myself.
Old 08-18-2019, 09:39 AM   #19
Nix125
My Country: Uk
�� lol were see if the Tcom board I ordered will fix the tv should arrive late next week.
Old 08-18-2019, 10:21 AM   #20
budwich
City & State: Kanata Ontario
My Country: Canada
Quote:
good question but probably not important. The reason being, is just measure and post the results. The "wrong voltage" will usually standout... low, high or otherwise. You aren't looking for an absolute value at this point.
further, the labeling isn't going to be "exact" for all set and hence look for things like "VXXX" or so as potential points of interest. As budm has indicated, those that he listed are a good "type" to look for.
budwich is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2021
Powered by vBulletin ®
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
