tv use to work then would tutn off and wouldnt power back on for a while . i took apart and touched up solder joints then no power at all. then changed those caps on the y sustain and tried last night no standby i checked fuses on power supply and there good
i just put solder on the top side of the caps as well and touched up the solder joints on the power supply powered on after a few times of hitting the button then died and wint do anything green light was blinking on control board and everything stopped when it went out
On that model, you disconnect the cable from the power supply and put a wire in the ps on and the other end to the ground. Then on the mainboard, put a wire in holes 3 and 4. Then plug in the tv.
okay i have the mainboard to ps supply mainboard connector unplugged and connected to pins 1 and 3 tried plugging tv in and nothing happened. i have to short 3 and 4 on the mainboard? where is 3 and 4 or i add another wire to the same connector on 3 and 4 thanks
tried this and still cant get test patterns. do i have the clip in the right spot on the logic board as mines a bit different then the pic in the pdf thanks
