hello, customer said that this problem started suddenly without any water damage or fell down, so i started with dell diagnostics and it passed all tests without any problems, the problem is when its goin to boot windows it freezes in the windows logo, i tried to boot from usb and it does the same, i tried to boot linux and it freezed when it was starting services, i also noticed that i dont have +vcc_gt all other coils measured and it seems ok, i also tried 6 different bios dumps and it does the same nothing changed and no signs of corrosion in the motherboard.
Dell 5567 (P66F LA-D801P i7-7500 + amd discrete gpu) freezes while booting windows.
Re: Dell 5567 (P66F LA-D801P i7-7500 + amd discrete gpu) freezes while booting window
try bios first, you can try to bga VGA chip.
BIOS - https://www.badcaps.net/forum/showthread.php?p=1027538I'm not happy to be so strong. because it's not humanly
Originally posted by kosmo View Postok i flashed the dump you sent me and it does exactly the same, i also noticed that when it turns on the +vcc_gt spikes instantly to 0.43v before the post and then goes to 0 again.
Try this bios - https://www.badcaps.net/forum/showpo...1&postcount=28 .
There`s already quite a few bios posted for the LA-D801P, some have AMT enabled,AMT disabled,no bootguard, bootguard FVME 5 . It might not fix your problem but worth a try.
Originally posted by kosmo View PostOMG! i disabled everything from bios from perfomance and i logged in!!with the last bios you send me!! now i enable one by one to see whats the option that gives the trouble.
Originally posted by Sametbey View PostYou are welcome. Can you explain the setting that you changed on bios?
