Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices
Thread Tools Display Modes
Old 04-16-2020, 12:44 PM   #1
meraklinetx
City & State: istanbul
My Country: turkey
I'm a: Knowledge Seeker
Default lenovo ideapad 110-15ibr very strange problem
Hello to All
İ have an lenovo ideapad 110-15ibr with an motherboard cg520 mn-a804 rev 1.0 the problem is that ;
When i were surfing over internet (windows 10) laptop stoped responding , so i forced power off with power button keep pressed , after when i try to power it on, its ggetting power on but with no display then powers off after an few (4 ~ 10) seconds and always like this, i take out motherboard removed all power, bios battery and keep pressed power button 30 or may be more than 30 secs, but no change, i measured all the voltages of all coils, all are ok and present (3.3v,5v,1.35v,1.8v,0.9v , 1.05 no any mising voltage on all coils) i also flashed 2 different bios with an external spi flasher but all same symtoms, power on , no display after an while powers off.
At this sutiation mainboard consume 0.16A ,then when goes off current goes 0.01A (when you plugged adapter or psu , mainboard drains 0.02A then start to autopower on then goes to 0.16A then goes again 0.01A and powers off and this is like that cycle untill you press power button again, with all bios i flashed are same as well , but what i noticed is that, when you remove bios chip from the motherboard, and connect power , the system is powersnon again and newer powers off, it stays like that untill you cut power and that time current drain is about 0.20 - 0.22A , and this is so strange, when you re program bios chip and put back , its again 0.16A powers on and then off 😀😃😄 , what may be the problem ?? What to do next??
NOTE: There is no blown or damaged chips or components on motherboard , also there is no short circuit, the mother board also has onboard ram , (there is no ram slot as well to put any ram, ) and onboard celeron cpu, also i could not see an HM and GPU chipset on mother board , i think all is in cpu. Also even cpu has not an cooler fan 😀😃😄 only with an crappy heatsink
What my be the problem?? Can be an defective on board ram problem??
meraklinetx is offline   Reply With Quote
Old 04-16-2020, 06:09 PM   #2
meraklinetx
My Country: turkey
Default Re: lenovo ideapad 110-15ibr very strange problem
No boady does not any idea??
Old 04-17-2020, 12:57 AM   #3
kodox
City & State: West Java
My Country: Indonesia
Line Voltage: 220VAC 50Hz
i think it's the bios indeed if all the PWRGOOD & RST signal are present, a schematic or boardview would help to find those signal
kodox is offline   Reply With Quote
Old 04-17-2020, 04:24 AM   #4
meraklinetx
My Country: turkey
Quote:
Thanks for your answer but i tested 3 bios (including orjinal) all is same symtoms and also all power outs coils are good ,but i did never programmed the EC firmware , can be the reason this ?? because i dont have flasher for ec chip, can i use the cf (cheap chaniese usb flasher) to program ec ?? If so how ?
Old 04-18-2020, 10:46 AM   #5
pepegotera454
City & State: andorra
My Country: andorra
It is a problem in a secondary source, you would have to monitor the different secondary sources with an oscilloscope, so you can see when this source falls.
pepegotera454 is offline   Reply With Quote
Old 04-19-2020, 06:06 PM   #6
orla
City & State: Medellin
My Country: colombia
You already tried if the screen gives you video, it may be that video chips are heating up and therefore the attention or the voltage drops.
orla is offline   Reply With Quote
Old 04-23-2020, 11:16 AM   #7
meraklinetx
My Country: turkey
Quote:
No it has no video chip already , its all in cpu (hm chipset, gpu and cpu is on 1 chip all) also , i reflow cpu , write 3 different bios, all same , there is no mising voltages as well but same sutiation, stand by power ok, it goes up to 0.16A than powers of after in 4 ~ 8 sec. (Goes stand by state again) , dont know what to do more or what to do next?? Please any advise ??
Old 04-23-2020, 01:01 PM   #8
teknikbursa
City & State: turkey
My Country: turkey
it is most probable cpu problem.
teknikbursa is offline   Reply With Quote
Old 04-24-2020, 11:21 PM   #9
ktmmotocross
Boardkiller
ktmmotocross's Avatar
City & State: slovakia
My Country: slovakia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
ktmmotocross is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
