Old 06-22-2013, 05:39 PM   #21
kevinm34232
City & State: Sarasota/FL
Default Re: Viore PD50VH80 50" Plasma`
Regarding the transistors in post #6, is this a problem?
kevinm34232 is offline   Reply With Quote
Old 06-23-2013, 12:41 AM   #22
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
Originally Posted by kevinm34232 View Post
Should I have 120VAC on both sides of this component?
Yes, I think so.
Free service manuals: http://www.toms-service-manuals.com/ -- 72 LED/LCD TVs, 5 monitors, 28 plasma TVs, and 2 AVR 6.1 amplifiers fixed! -- I repair Pioneer 9G Plasma Main Boards & KRP-M01 Media Receivers (PM me for info)
2 Pioneer KURO 9G, 12 Panasonic LCD/Plasma, 1 Sony LCD, 1 NEC Plasma, 2 Yamaha HTS, 5 Sharp LCDs, 5 Toshiba LCDs, 7 Philips Plasma/LCD, 1 Hitachi Plasma, 11 LG LCD/Plasma, 18 Samsung LED/LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Grundig LCD, 1 Dell LCD, 1 iiyama LCD, 1 Acer LED, 1 Logik LCD, 1 Baird (China) LCD, 6 Bush LCDs, 22 Vestel LCDs (Best->Worst)
Old 06-23-2013, 08:08 AM   #23
kevinm34232
OK trying to trace this to the best of my ability..
Tom is the spot with the ? where the 2nd relay would give the bridge the HOT side 120VAC?
I have the 120VAC at the 2 spots noted, where it hits those 2 diodes. Is this where it's going to the standby section?
So is the AC sectioin fine then?
Old 06-23-2013, 08:15 AM   #24
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
I don't have a schematic of the exact same board but I have one from a different model, same generation. You should be able to understand how the input circuit works -- more or less the same.
http://www.toms-service-manuals.com/...df&mfg=Samsung
Old 06-23-2013, 09:06 AM   #25
kevinm34232
Thanks for that..
What is the TH relay for? Neither one is clicking on, but I do have 120VAC across pins 1 and 2 of RL802S, but not RL801S.
Which relay circuit do I need to focus on?
Old 06-23-2013, 09:17 AM   #26
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
The TH relay bypasses the NTC once the power supply has started, this improves efficiency. The TV can work if this relay does not energise but it can lead to picture issues and overheated NTCs.
The ON/OFF relay turns the main power on to the PFC circuit which boosts the supply to 400V. The standby should still work without this relay functioning.
Note the 22F/450V should have 160V in standby (US) and around 390V in operation, as it gets an extra feed in from the PFC circuit. If you don't have anything (160V) at that capacitor, then there's a fault on the input circuit somewhere or a blown fuse that's not obvious somehow.
Power on sequence (after power button pressed):
- ON/OFF relay toggled
- ~100ms delay
- TH relay triggered
- PS ON signal activated
Old 06-23-2013, 09:48 AM   #27
kevinm34232
I traced back from the + of the 22uF/450V cap and it only goes thru the fuse next to it, then thru 2 diodes (DB810 and DB811) back to the pins where I have 120VAC at the NTC. Diodes seem to be fine and there is 120VAC at the anode of DB810
But I only have about 1VDC across that cap.
Old 06-23-2013, 10:19 AM   #28
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
The diodes are not open? No cold joints? Try measuring the voltage drop across the diodes that feed that cap.
Old 06-23-2013, 10:23 AM   #29
kevinm34232
Does it matter which probe to where, or just either way across the dioide? DC or AC? Also, can I measure the V out of each diode and what would I use for ground?
Old 06-23-2013, 10:27 AM   #30
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
What meter do you have -- is it True RMS capable? If so, AC or DC range across them will work.
Old 06-23-2013, 10:37 AM   #31
kevinm34232
It's a cheapie meter. Set on AC I get a reading of around 7V across the first diode, about 0.5V across the second one.
Old 06-23-2013, 10:48 AM   #32
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Can you highlight that diode on the board somewhere?
Old 06-23-2013, 11:01 AM   #33
kevinm34232
Here's from the bottom I will get from the top now, which diode are you looking at?
Old 06-23-2013, 11:08 AM   #34
kevinm34232
From top../
Old 06-23-2013, 11:12 AM   #35
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
Well, it's just a 1N4007. You could try replacing it (radioshack sell them) along with the others near it -- just leave the diode DB801 near the transformer alone.
Old 06-23-2013, 11:25 AM   #36
kevinm34232
You're talking about the one next to the cap? What should I expect to see as the 120VAC goes into the first diode into the 2nd one, it should be coming out at 160VDC?
Old 06-23-2013, 11:28 AM   #37
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
You should have 160V across the cap, but the layout of the diodes is really unclear I'm not sure what they each do. I wish I could get the exact schematic.
Old 06-23-2013, 11:39 AM   #38
kevinm34232
I have a UF4007GP-TP will that work for the 1N4007?
Old 06-23-2013, 11:41 AM   #39
tom66
tom66's Avatar
City & State: Leeds
My Country: UK
That will be fine it is the ultra fast variant of the 1N4007 and would in fact be suitable for DB801 too, though I don't think you need to replace that.
If you give up, the board is about $50.
http://www.shopjimmy.com/samsung-lj4...upply-unit.htm
Old 06-23-2013, 11:49 AM   #40
kevinm34232
Ya I got a offer in on one on ebay now for $30. I hate to give up on it tho, Im gonna try replacing that diode, perhaps lifting the diode next to it that also goes to the fuse and then goes somewhere else.
Nah didn't work.. There is a 6 pin ICB801S (ICE3BR2565JF) close to this cap
http://www.alldatasheet.com/datashee...3BR2565JF.html
Could you look at this I think it produces the standby?
Checking the from the cap ground, it showing a short to pin 2 (current sense). Is that normal?
Edit: There is 0VDC to the VCC pin, that pin leads to a pin on the TB801S transformer.
I will try to search for a schematic
