Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices > BIOS Requests ONLY!
Old 04-04-2017, 06:08 AM   #21
bello
City & State: Srebrenik
My Country: Bosnia and Herzegovina
Line Voltage: 220 V AC, 50Hz
Default Re: SAMSUNG NP700Z7C - BIOS dump needed
There is original, maybe corrupted:
bello is offline   Reply With Quote
Old 04-04-2017, 04:52 PM   #22
techman1025
City & State: Fairfield, New jersey
My Country: United States
Line Voltage: 120VAC 60HZ
Here
Techman1025
techman1025 is offline   Reply With Quote
Old 04-04-2017, 11:26 PM   #23
whaldsz
City & State: NE
My Country: Philippines
Line Voltage: 220VAC 60Hz
try this.
whaldsz is offline   Reply With Quote
Old 04-05-2017, 03:36 AM   #24
bello
Thanks for fast answer. Flashed with techman1025 dump now I have progres bar with Phoenix logo but stucked, can't enter into bios with F2 or F4. With whaldsz dump behaves same as original...
I think motherboard is bad??
There's pictures:
Old 04-05-2017, 10:21 AM   #25
techman1025
Hi
Pull Cmos battery for a few min and hold power button down then plug adapter only and retry.
Techman1025
Old 04-05-2017, 01:17 PM   #26
bello
I tried it already...
Customer says that sometimes the start, after many attempts. The disc is correct, it is possible that the failure of the board ...
Old 04-05-2017, 04:59 PM   #27
techman1025
Hi
You could try a new bios chip and reprogram it with mine. Also try with only one memory stick in and do the same for the other socket see if it hangs so only one at a time you might have a bad stick of memory or a bad socket if one socket is bad double up on one socket is the only fix.
Techman1025
Old 04-05-2017, 06:26 PM   #28
whaldsz
City & State: NE
ok, try again with this one.
Old 04-06-2017, 02:50 AM   #29
bello
@techman1025
I tryed it also, one memory is soldered on the board and can't remove it. Also tryed with another bios chip...
@whaldsz
Nothing, same as other...
Anyway thanks a lot.
E.Lelic
Old 04-06-2017, 08:40 AM   #30
techman1025
Hi
What i would do is put some good flux under the onboard memory chip's and apply a little heat like 100C then retest if it works you could always replace them.
Techman1025
Old 04-07-2017, 03:39 AM   #31
bello
I tried to provoke him in the hot state, but nothing...
I think I'll give up.
Old 04-07-2017, 02:30 PM   #32
techman1025
I AGREE
Techman1025
Old 04-21-2017, 03:51 AM   #33
lining
City & State: Skopje
My Country: Macedonia
NP700Z7C ba92 11017b dump maybe? accidentally erased the stock firmare before backup it first in my programer. I tried with last firmware whaldsz posted for BA92-10916B and only get backlight of the display and then he is restarting again and again and again
lining is offline   Reply With Quote
Old 02-24-2019, 01:29 AM   #34
jadao
City & State: Montreal, Quebec
My Country: Canada
I need NP700Z7C BA92-10916A working bios, any chance someone have it?
It is stuck in samsung logo.
Here is the suspected not working dump.
jadao is offline   Reply With Quote
Old 07-04-2020, 03:59 PM   #35
xe_d_sono
xe_d_sono's Avatar
City & State: Alentejo
My Country: Portugal
The solution to this Samsung Series machine is remove the dead iSSD flash from Sandisk. This cause a long freeze on boot.
I hope it helps.
Br
xe_d_sono is offline   Reply With Quote
