Telefunken 48" TLEDD-48FHDA not starting up.
  • angelos
    • Dec 2012
    • 567
    • South Africa
    Hi guys, I need a little bit of advice on this as i cannot get a schematic for it.
    Upon powering up the tv the standby light is on but after about 2 seconds it goes off and remains off. Pushing the standby button makes no difference. No picture, no backlights nothing.
    This is what i have observed. The panel voltage (12V) does not come on.
    Various voltage points have been checked (please check photo) but i do not know if they are correct. Only suspicion is the DC to DC converter that;s outputting 1.15V. Maybe it is supposed to be 1.2V or 1.8V don't know.
    What if the eprom is corrupt?
    Couldnt find firmware anywhere for this board. Any help anyone?
  • angelos
    • Dec 2012
    • 567
    • South Africa
    Re: Telefunken 48" TLEDD-48FHDA not starting up.
    The PCB number is TP.V56.PB801
    • angelos
      • Dec 2012
      • 567
      • South Africa
      I found that my 3.3V rail is low at 2.8V. I traced it back to a SMD chip with marking "1118" on it. The chips input power is 5.1V then there are two outputs, 1 = 1.8V and 2 = 2.8V (this is incorrect)
      What is this chip?????
      • R_J
        • Jun 2012
        • 9535
        Lt1118 ldo regulator
        • angelos
          • Dec 2012
          • 567
          • South Africa
          Actually, its a bit different to the one you mention. Mibe isva dual output fixed low drop out voltage regulator namely LC1118CS8TR1833. Yeah, a mouthful.
          • angelos
            • Dec 2012
            • 567
            • South Africa
            Now for the long wait (4 months) to receive and complete the repair. This country has squat.
            • vicvc
              • May 2015
              • 13
              • south africa
              for simple test, use 3 diodes in series(1.8v drop) form pin 4 to pin 5. (anode pin 4) pin 4=5v, pin 5=3.3v. (1n4007). if cpu overheat, most likely original problem. longest one running +- 1 year(still running but for safety i replaced diodes with mini-adjustable regulator). china chassis collection (4 circuits) was downloadable from kent liew website.
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
              • ray14324
                Telefunken LED TV with no standby linght equipped with Vestel 17IPS20 PSU
                by ray14324
                Hi everyone,
                Searching the forum revealed loads of issues with this type of power supply board however I could not find a solution to my issue from them. Excuse the "another Vestel" thread
                The full story was: my Telefunken TV did not have a standby red light after of series of power outages in a couple of minutes. Sadly in my rural city the only technician that fixes TV's is away these days as I cannot reach him by phone. I want to try to have a go at it (with the internet's help).
                Reading into this symptom the general consensus was that...
                08-31-2021, 07:55 AM
              • fharris1977
                Vizio D50u-D1 Dead Set No Standby
                by fharris1977
                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                12-28-2023, 10:25 AM
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                The TV does not turn on, the standby indicator is on. All voltages are present.
                Emms is dead. Not readable, not detected.
                Replaced emmc.
                But with another dump there is no launch
                Terminal log
                UART
                AC_ON
                RPMB key is not yet programmed
                HASH1_VERSION=0x00000000 64bit
                E-B
                FDE enabled
                layout pattern onebin by SAR7,0...
                06-01-2025, 02:11 AM
              • Crystaleyes
                Samsung BN44-00259A standby question
                by Crystaleyes
                Hi all.
                I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                08-11-2023, 05:15 AM
