Old 07-06-2019, 08:32 AM   #1
angelos
City & State: Free State
My Country: South Africa
Line Voltage: 220V AC
Default LG 42" Plasma Model 42PG20R-AFB (No picture)
HI guys,
I have another beast of a TV and lack the knowledge to fault find which board to look at.
When starting this TV you hear a click and Vs and Va come up as per plasma label but there is no pre-charge and no picture. As a matter of fact the Y-SUS and Z SUS boards are not getting the slightest heat on the heat sinks meaning they are not being driven at all.
The led on front panel shows TV is in the on state and when I press vol+ or Vol- the standby light flickers indicating that the main is at some extent operating.
At this point i can suspect any board especially the logic control board which has only one green light with the other two being off or perhaps something wrong with the main board.
Unlike the Samsung where you can short out two pins on the control board and force the controller to generate a test pattern to the plasma boards on the LG i know nothing like that.
Any fault finding tips would be greatly appreciated.
Regards
Angelos
angelos is offline   Reply With Quote
Old 07-06-2019, 08:39 AM   #2
diif
City & State: Midlands
My Country: England
Default Re: LG 42" Plasma Model 42PG20R-AFB (No picture)
A photo of the logic board, there are usually a couple of holes that are bridged for the test pattern.
diif is offline   Reply With Quote
Old 07-06-2019, 04:09 PM   #3
angelos
Ok will upload when able to. Thanks..
Old 07-07-2019, 01:25 PM   #4
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
Clear focused close-up shots.
Andrew F. Ali is offline   Reply With Quote
Old 07-10-2019, 04:02 AM   #5
angelos
Here are the picture of both sides of the logic board as discussed.
Old 07-10-2019, 04:10 AM   #6
diif
My Country: England
Just to the right of the sticker, EXT_AUTO_GEN.
Old 07-10-2019, 11:47 AM   #7
angelos
Great. I will bridge the two pins and see what happens...
Old 07-10-2019, 11:50 AM   #8
tvtimmy
tvtimmy's Avatar
City & State: milwaukee,wi
My Country: usa
Line Voltage: 120VAC/60HZ
You also have to unplug the ribbon cable from the mainboard to the logic control board.
tvtimmy is offline   Reply With Quote
Old 07-11-2019, 03:27 AM   #9
angelos
Will do...
Old 07-13-2019, 06:40 AM   #10
angelos
Ok, i shorted the auto gen pins and removed the LVDS cable to the logic board. Switched on set and nothing still no panel drive.
Where do i go from here? I measure no shorts on Vs, Va etc. Those mosfets i tested all had no shorts on their pins.
Old 07-13-2019, 07:08 AM   #11
tvtimmy
tvtimmy's Avatar
My Country: usa
You will have to test the igbt's in diode mode. Removing them is best when testing.
Old 07-13-2019, 02:41 PM   #12
angelos
Have you had an igbt go open circuit? How do we test those since some transistors do not get triggered by the small voltage the multi metet produces or am i wrong?
Old 07-13-2019, 04:36 PM   #13
tvtimmy
tvtimmy's Avatar
My Country: usa
Yes, I have. I have a cheap transistor tester that I use, after testing with my DMM. See pics.
Sometimes original bad igbt's read like this too.
