Motherboard fan running before power on
  • utzlol
    • Apr 2020
    • 10
    • Indonesia
    Hi, i have a h81m-k motherboard. It wont turn on. And i realize the motherboard fan is running before power on. I check the +12V on fan socket (before power on), it has 5Vsb from psu and 12V cpu vrm also have 5Vsb and maybe that cause my motherboard immediately turn off after power on. Any idea how that can happen?
    • 30972
    Re: Motherboard fan running before power on
    so your psu is putting 5v on the 12v rail in standby?
    or your board is?
    • utzlol
      • Apr 2020
      • 10
      • Indonesia
      or your board is?
      The motherboard do that. I already cut the 12V cable from psu but the 5Vsb on 12V rail still appeared (It means the problem on the motherboard)
        • 30972
        so what do you see if you check between the 5v-standby and 12v pins with a meter set for resistance, and diode-mode?
        try with leads both ways.
        • utzlol
          • Apr 2020
          • 10
          • Indonesia
          I realized the different resistance between before power atx plug and after power atx plug (but the psu seems normal, cuz i already try with different board and that normal)
          After atx plug
          GND - 12V (88 ohm)
          GND - 5V (86 ohm)
          12V - 5V (173 ohm)
          Before atx plug
          GND - 12V (113 ohm)
          GND - 5V (742 ohm)
          12V - 5V (858 ohm)
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            Like, an ich fan? The h81m-k dosen't have one.
            • utzlol
              • Apr 2020
              • 10
              • Indonesia
              What is ich fan?
                • 30972
                ich is chipset
                • utzlol
                  • Apr 2020
                  • 10
                  • Indonesia
                  I mean that happened to the all motherboard 4pin socket. It appeared 5Vsb on the 12V fan voltage, that cause the fan spinning before power on. I think because of that, the 5Vsb short to the 12V rail. And no idea which the component cause that.
                    master hoarder
                    • May 2008
                    • 12170
                    • Bulgaria
                    Can we have some pictures of the setup and the PSU?
                    What brand and model is the power supply?
                    Does the PSU fan run when connected to the motherboard?
                    - If yes, then disconnect PSU from the motherboard and plug PSU into the wall. Does the PSU fan spin now? Does it has 5VSB showing 5V, but all other outputs zero (or close)?
                    Also, what's the history on the PC you are troubleshooting? Is it yours or someone else's? Do you know when or what (last use) caused the PC to malfunction?
                    • utzlol
                      • Apr 2020
                      • 10
                      • Indonesia
                      Ah my bad. The motherboard had a failure bios that make it turn on/off repeatedly
