Old Gateway 2000 speakers out of sorts.
Re: Old Gateway 2000 speakers out of sorts.
Thanks Budm, measured the KIA324P's:
speaker off and powered on: 1=6.3 on=5.9 6=6.2 on=5.8 12=4.9 on=4.7
7=6.2 on=5.8 13=5.1 on=4.7
2=6.2 on=5.9 8=5.1 on=4.8 14=5.1 on=4.8
3=6.1 on=5.7 9=5.0 on=4.8
4=13.6 on=12.7 10=5.0 on=4.7
5=6.1 on=5.7 11=0 on=0 both chips measure the same.Last edited by nomoresonys; 06-27-2020, 12:31 PM.Comment
How about the power amplifiers TA?
Did you make the probe yet?
Also you need to try using stereo headphone to see if all the controls work OK or not.
The little board with the small IC4560 is the headphone amplifiers fro driving headphone with the switched jack that will cut out the signals to the TA power amp and the sub woofer output when headphone is plugged in.Last edited by budm; 06-27-2020, 02:25 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
Do I need something like this or is there even a more simple build? https://www.youtube.com/watch?v=1GVZWRinypULast edited by nomoresonys; 06-27-2020, 04:29 PM.Comment
That is fine, same concept as I suggested in the link, nothing complicate, very simple.Never stop learning
I made this simple amplifier: https://www.youtube.com/watch?v=jyRwzXMm0FEComment
Used this mosfet: https://cdn.badcaps-static.com/pdfs/...4aba46b876.pdfComment
Was trying to put up pictures but the camera refuses to connect, I made this probe, the end of the probe is just the 2 wires, wonder if I can use the probe and amp to troubleshoot the speakers: https://www.youtube.com/watch?v=IEcyDzYAsuUComment
The link I gave you use the powered PC speaker attached to the probe that I told the OP to make, basically the same as the one in your probe video. Don't you have any PC powered speaker around or any audio amplifiers?Never stop learning
Had one extra set, tried to make them work but couldn't get any sound from the probe, they just hummed, no reaction when I touched the probe end to anything, no audio amps but the one I made works.Last edited by nomoresonys; 07-02-2020, 01:58 PM.Comment
I bought a small premade amp but won't get it for at least a week.Comment
You should be able to probe the audio output of the PC feeding the Gateway speaker since the Gateway is getting the audio signal so it should be present. The ground of the probe is connected to the circuit ground of what you are probing, correct?Never stop learning
Had the ground on the heatsink of acl's, maybe that was wrong?Comment
You just have to Ohm it out, or you can just use the negative leg of the main filter cap.Never stop learning
Thinking about switching the big cap 2200uf with a 4700uf that I have on hand, do you think it will hurt anything to go up that high? voltage is 35 the 2200 is 25, I might have a 3300 somewhere.Last edited by nomoresonys; 07-03-2020, 03:21 PM.Comment
At this point I would not deal with the main filter cap yet, higher capacitance will cause higher inrush current for the wallwart.
BTW, did you try using stereo headphone to see if both channels work OK or not, if it does that will help narrowing down the problem.Never stop learning
Oh crap my bad, I thought I reported but didn't, I tried the headphones and they work good, full volume and all.Comment
So that means all the pots are OK, preamp section are OK all the way to the headphone amplifier board, so I would probe the input pins and the output pins of the TA IC with your audio probe next.Never stop learning
by cazi1001Hello,
I have a Samsung Galaxy A22 5G with a strange error image.
If I have a call, I can't hear the voice of the interlocutor and he can't hear me.
If I switch on the lower speaker, I can hear the interloutor through it and now, he can hear me too.
If I listen music via Youtube, even the upper or lower speaker don't work.
If I switch louder or quieter, the sign on the screen show me a headphone.
If I plug a external speaker via Jack plug or USB-C, I can hear the sound.
Does anyone have any ideas, what the problem could be?02-10-2024, 09:16 AM -
Hello to the forum.
My name is Christos, I am new to the forum here and i am posting from Greece.
So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
So i tried asking for a schematic from the company and they would not give me one. Instead they...-
Channel: Troubleshooting Audio Equipment
This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:30 PM
- Loading...
- No more items.
