Old 07-02-2020, 08:49 PM   #1
Rafaelmangsat
City & State: Pangasinan
My Country: Phillipines
Post Toshiba satellite c55d-a5108
Hi all
I have a customer laptop that have problem no lcd display even external display to vga and hdmi output.
Can power on ,ok
If remove ram has beep sounds, ok
Keyboard beeps sound ,ok
Fan working ,ok
Troubleshooting done:
Clean ram
Put thermal pad/paste for processor
Change ram from other working laptop
Reset bios/remove battery
Reprogram bios from ezp2019
And even reflow or reheat processor just normal reheat/reflow not yet put flux bec. To dangerous for processor
Output the same no display internal and external monitor
Please can any body help me with this problem
Or can any body encounter this problem and what you do to make it work again
Pictures attach
Tnx all especially admins
Rafaelmangsat is offline   Reply With Quote
Old 07-02-2020, 11:04 PM   #2
mcplslg123
City & State: siliguri
My Country: india
Line Voltage: 220vac,60hz
Default Re: Toshiba satellite c55d-a5108
Here is the link for boardview
https://www.alisaler.com/toshiba-c55...a02-boardview/
Check voltage on all coils and see if any rail is missing.
You can try this bios also
https://www.alisaler.com/toshiba-c55...-amd-bios-bin/
mcplslg123 is offline   Reply With Quote
Old 07-02-2020, 11:07 PM   #3
Rafaelmangsat
Tnx i will update if it work
Old 07-02-2020, 11:17 PM   #4
lobz
City & State: NEW YORK
My Country: Andorra
The only defective component who give you any pictures on your internal or external screen is the GPU, or something around it.
lobz is offline   Reply With Quote
Old 07-03-2020, 12:03 AM   #5
Rafaelmangsat
Still no luck no display in lcd and external monitor
Old 07-03-2020, 12:40 AM   #6
Rafaelmangsat
Can anyone tel me where is gpu in this motherboard or it is in processor combine gpu n processor
Old 07-03-2020, 03:27 AM   #7
Duranitron
Duranitron's Avatar
City & State: Caloocan, Manila
My Country: Philippines
Line Voltage: 220VAC 60hz
it is integrated to the AMD processor if all the power rail is present.. the integrated gpu most likely it gone bad..
Never stop LEARNING because life never stops TEACHING!
Duranitron is offline   Reply With Quote
Old 07-03-2020, 03:36 AM   #8
Duranitron
Duranitron's Avatar
i only assume.
Old 07-03-2020, 03:39 AM   #9
SMDFlea
Moderator
City & State: York
My Country: UK
Originally Posted by Duranitron View Post
overheating problem...did you check the cpu fan.. any blockage like a foam or something inside.. its the culprit for most laptop for premature breakdown specially in tropical country dust accumulation that chokes the processor to death \
He said at post #1 the fan is working OK .
SMDFlea is offline   Reply With Quote
Old 07-03-2020, 04:57 AM   #10
Duranitron
Duranitron's Avatar
maybe he is not the only one that tries to repair it.. i only assume
Old 07-03-2020, 01:46 PM   #11
Rafaelmangsat
So i guess no one encounter this on this laptop brand... so gpu/processor reflow again 50/50 might death or alive
Old 07-03-2020, 11:46 PM   #12
Duranitron
Duranitron's Avatar
if the gpu fails.. reflowing doesnt repair it you need a new processor..
Old 07-03-2020, 11:49 PM   #13
Duranitron
Duranitron's Avatar
maybe the first attemp to reflow it... kills it.. this is the problem of most integrated processor and gpu.. it is disposable..the processor is good but the gpu is bad theres no fixed there but to replace it..
Old 07-04-2020, 12:00 AM   #14
Duranitron
Duranitron's Avatar
just replace the processor/gpu.. to solve your problem.. make sure when you buy a new amd processor just indicate to it the balls must be lead type dont buy the lead free type just a suggestion the lead free type if you dont have a reflow machine you will definitely kill it due higher melting point of the lead free solder. mahal din ung amd processor tol.
Old 07-04-2020, 12:50 AM   #15
Rafaelmangsat
Ok tnx bro.. i just reflow no luck again today... ok i take ur suggestion.. tnx
Old 07-04-2020, 02:32 AM   #16
Duranitron
Duranitron's Avatar
before you attempt to replace the processor.. try to find shorted cap around the processor area in some cases thats the only problem but if you cant find shorts definitely your only option is to replace the amd processor
Old 07-04-2020, 08:31 PM   #17
Rafaelmangsat
Bro can i replace this 330 two pin to 470 3pins? Pin2 n 3 are ground
c picture
The other 470 is pin1 n pin2 to pin3 shorted the other 470 is not shorted
Pls advice
Old 07-04-2020, 08:42 PM   #18
Rafaelmangsat
Anyone advice pls tnx in advance
Old 07-04-2020, 11:18 PM   #19
Duranitron
Duranitron's Avatar
you need to stick to the original value.. that cap value is there for a reason..a 10% tolerance maybe use but 470 is way too high...its almost 50% tolerance,, my opinion...
Old 07-05-2020, 01:38 AM   #20
Rafaelmangsat
tnx bro
