Hi guys.
I ordered used ROG front base guy claiming it is working.
But when I got home,I installed it with my MoBo which is supported and only got white backlight..
It was a rip off,luckly did not paid much for this thing.
But carefullly inspecting the board I see broken notch on SATA connector so my assumption is that maybe someone was installing the SATA power cable from PSU in opposite direction and fried "something" on board (look at the pic below).
So with your guys experience what do you think, if that is the case, what component(s) could be dead, and what to test and how in order to try to repair this thing?
Luckly I ordered second one, this time from other guy claiming this one is working.
So maybe I will have 2 of them and judging by the working one maybe I could test the working one and compare voltages,ohms,amps or diode mode with failed one.
But I dunno which components should I test first for failure?
I did some pics so you guys can see the PCB.
