looking for asus ux32vd rev 2.1 bios dump
  • gvidonis
    • Jan 2017
    • Lithuania
    looking for asus ux32vd rev 2.1 bios dump, loptop stuck on asus logo so maybe bios reprograming gonna help, plz share if someone have
  • Ikung
    • Nov 2013
    • 34
    • Malaysia
    Re: looking for asus ux32vd rev 2.1 bios dump
    Did you try to remove/replace your hard disk? It seems to me like a hard disk failure.
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      Send old bios i try fix.
      • flashcap
        • Jul 2017
        • 3
        • Belorussia
        Dump from nb with faulty video, UX32VD rev 2.2
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          On this model is common a pch issue, look at its corners to see if glue is firmly in place or it's easy to remove
          • nheltech
            • Jul 2018
            • philippines
            • peste
              • Dec 2016
              • 12331
              • ROMANIA
              post the original bios of the laptop and pictures of the stickers in the ram memory area
              • welder
                • Apr 2017
                • Estonia
                Asus UX32VD main board Rev. 2.1 original bios dumb.
                Macronix 25L6445E
                • zigana
                  • Aug 2013
                  • 38
                  • turkiye
                  thanks
                  • muradterzi
                    • Aug 2017
                    • 39
                    • Türkiye
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • Anchar777
                      ASUS P1412CE need BIOS DUMP
                      by Anchar777
                      Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                      06-26-2025, 03:39 AM
