A1708 820-00840 no power
    hello everybody my macbook a1708 is giving me some issues:
    no power and no amp consumption i have replaced c7078 was shorted to ground. voltage checked :
    ppbus_g3h=0.3
    ppdcin_g3h_chr_r=5.1v
    ppvin_g3h_p3v3 g3h=3.8v
    pm_en_p3v3_g3h_r=4.6v
    pp3v3_g3h_vr=2.2v (required 3.3v)
    pp3v3_g3h=2.2v (required 3.3v)
    no short to ground
    tanks
    Re: A1708 820-00840 no power
    ppbus_g3h=0.3
    STOP.
    Remove the fuse @ F7000. Then, meter in DC volts mode (30V or higher is ok).
    Red meter probe to F7000, pin # 1 (ISL side) PCB pad.
    Black meter probe to ground (shield is ok).
    What is the voltage to ground ?
    Next, meter in RESISTANCE mode. Remove all power.
    Check the resistance to ground of F7000, pin # 2 (downstream / consumer side) PCB pad.
    One meter probe on F7000, pin # 2 PCB pad.
    Other meter probe to ground.
    What is the resistance to ground ? Make a note of the meter scale if it is not automatic scaling.
    Post your readings. From the very low voltage, sounds like you have a shorted capacitor on the downstream / consumer side of the logic board.
      tanks sir for reply.ok I will do all that tonight, I also want to inform you that after replancement of diode D6905 the voltages have changed:
      ppdcin_g3h_chr_r= 20v
      pp3v3_g3h_vr= 3.4v
      pp3v3_g3h= 3.4v
      ppbus_g3h=0.3
        voltage on F7000 pin 1 = 0.123v
        when I was measuring the voltage across f 7000, I noticed that f 7000 has a high resistance about 470k,replaced from donor board same issue
          Do you have F7000 removed or on the board ?
          The fuse must be removed to check if the PPBUS_G3H voltage rail is being generated.
            yes i have removed f7000 but still no generate voltage
            how much voltage should be on f7000 when removed?
              Bad dual diode and possibly resistor feeding PP3V3_G3H input as always.
                I believe that the diode seems good, I have checked with meter, the last one was open on point 1 and 3
                ppbus_g3h can generate the voltage without battery in?
                  Yes. One leg of the dual diode is a feed from the battery.
                  Other leg of the dual diode is a feed from the external power adapter.
                  The diode will select the higher of the 2 sources to create the PPVIN_G3H_P3V3G3H.
                  This input feeds the regulator @ U6990.
                  Review the voltage to ground on each leg of D6905 (dual ANODE diode).
                  Next, check the voltage to ground of PP3V3_G3H @ L6995, pin # 2.
                  Post each measurement.
                    the voltage on D6990:
                    pin1: 0,3V
                    pin2: 20V
                    pin3: 19
                    PP3V3_G3H on L6995: 0,23v
                      sorry its D6905 not D6990
                        So this rail is missing. This rail may have a shorted part on this leg.
                        Remove all power. Meter in resistance mode.
                        Measure the resistance to ground of L6995.
                        Post the resistance reading.
                          black probe to ground red probe to L6995 :130k
                          red probe to ground black probe to L6995 :2.8k
                            voltage on L9695 : 3.4v
                              From post # 10
                              Which is correct ?
                                sorry PP3V3_G3H is 3.4v
                                  pin1: 0,3V
                                  pin2: 20V
                                  So PPBUS_G3H is now @ 20V ?
                                  Can you confirm this? What changed ?
                                    checking resistance between PPBUS_G3H and the output of buck converters:
                                    L8030: 1m
                                    L8060: 0.8m
                                    L7960:
                                    L7900:
                                    L7730: 1.5m
                                    L7690: 15m
                                    L7670: 12m
                                    L7430: 8m
                                    L7370: 7m
                                    L7220: 6m
                                      no sir PPBUS_G3H is 0.037v
                                        to confirm:
                                        PPDCIN_G3H_CHGR_R : 20v(pin2 D6905)
                                        PPBUS_G3H_R : 0.037v (pin1 D6905)
                                        PPVIN_G3H_P3V3G3H :19.76v (pin3 D6905)
