ASUS AIO ET2012IGKS GPU issue
    today has arrived an ASUS AIO ET2012IGKS M/B ET2012E Rev 2.00G.
    GPU (ATI Radeon HD7470M) is almost dead: black screen (frequently) or screen corruption (sometimes).
    Is there a way to disable the Radeon and enable the Intel GPU (HD 2000) ?
    Thank you !
    Re: ASUS AIO ET2012IGKS GPU issue
    do you have any schematics or boardview of this board?
    you need to find and see what phase goes to the gpu core and try to lift it up. i don`t know if it work but you need to search the forum because i know there are people who manage to convert it.
      Hi dj_ricoh,
      I've found the boardview (attached)
      I'm looking for the schematic...
      Thank you !
        Removing PQ8947 could do the trick without removing the bad GPU ?
          Hello , I have an aio asus et2012e , with broken video card , I bought in china another that works but I do not work the black light on the screen . The fuse on the board was broken I replaced it but it doesn't work the same. With an external monitor everything ok. With the original card the black light works , I do not understand what to check. Has anyone had the same problem? Thank you.
            fuse dont blow itself
              were you able to fix it?
                Unfortunately not
