Got this junk brand ATX power supply board extracted from a dead power supply. There is only a label of SXJ2010 V1.4 from underneath the pcb. It only has 5v standby power.
I removed the original 5A glass fuse and soldered on a 60w incandescent bulb as current limiter. Upon power on to mains 230v ac, the bulb lighted brightly and then shuts off. By using a multimeter, i got about 100vdc on each of the main cap of 470uf, 200v. There is no other voltage on the secondary side apart from the 5vsb purple wire.
My question is it safe to take measurement of dc voltage from the three transformer on the primary side? I guess my negative probe should be on the negative side of main cap while positive probe should place on the primary transformer leg. I am using this cheap board only for learning purpose and not to power any other electronic item.
