Hitachi DV-PF4E VCR/DVD Combo - no power
    Re: Hitachi DV-PF4E VCR/DVD Combo - no power
    The main filter capacitor may also be bad, and check each diode in the bridge circuit, one might be bad as in open. You should have around 340vdc ACROSS the main filter capacitor.
    I suspect you are using chassis ground to check the main filters voltage and not hot ground and that is why the reading is low
