hello folks
I need some help to see if anyone can Identify this (IC) I believe its a Reg of some type I will post some pics as well. its in a test equipment hand held network tester its part of the power side of it its a 6vdc rail only thing on the chip is as follows (BPV 7CK EYL9) Its a 10 pin Plus bottom ground plane
I am including a layout/pinout of the ic and what i had on the traces that go to the Reg as best as i can see and test pins 2 and 4 were shorted is what i found with the ic under thermo cam it was getting 300+ almost instant pulled off pcb and no more short now need ic chip to replace but cant find the part numbers i have tried turned up nothing thanks for any input or info
I did find this but not sure how reliable it is thanks
TPS63002DRCR TPS63002DRCRG4 TPS63002DRCT TPS63002 BPV【IC REG BUCK BOOST SYNC 5V 10SON
after checking the schematic for these it sure looks like it the only thing is there power rating for the ic is 5.5v and for a 1 0r 3 cell battery and i have a 4 cell battery 1,5 x4 =6vdc am i missing something?
