Will transplanting 1 eMMC from1 device to another device of same model make it work?
    Quick Question. If you have 2 identical android phones, same model.(Device 1 and Device two) If you transplant the eMMC from device one onto device two. Will it work or do i have to transplant the CPU too?
    Re: Will transplanting 1 eMMC from1 device to another device of same model make it wo
    If there is a binding to the processor (keys) in the eMMC firmware, then it will not work (only with the native processor).
      Hmmmm.. I think i will just try dump the emmc and back up the stuff in the working phone.
      Thank you
        Thank you
        i think you can try, it can work but just for save the data only. Maybe baseband will lost.
          I managed to get usb working again by reballing the ic RT5081. Managed to dump the firmware and using poweeriso i can see the system folders.
          Is there away to extract userdata been trying power iso for awhile and nothing...
            you never did say what it is.
              I wanted to dump the phones eMMC
              The Phone is a Tecno AX8( Phantom 8)
              I managed to dump the ROM using Miracle Thunder(MTK Tab) All Bin Files.
              I checked the filesystems using cygwin System folder is EXt4, userdata.bin says data.
              Thats where i am at.
              Now i am looking for a way to read or mount the userdata bin file.
                do you see filenames or text with a hex editor?
                if not then it may be encrypted
