I’ve got an Asus Z170-A motherboard that supports 1 or 2 or 4 DDR4 memory Channel configs.
It has memory slots DIMM_A1,DIMM_A2, DIMM_B1, & DIMM_B2.
The manual says you can have:
Singe channel using DIMM_A2
Double channel using DIMM_A2 & DIMM_B2
Quad Channel using slots DIMM_A1,DIMM_A2, DIMM_B1, & DIMM_B2.
The only combination I can get the board to boot with is single stick in DIMM_B2 or two sticks in DIMM_B2 & DIMM_B1 ?? According the to manual this configuration shouldn't be possible.
I’m using four matched DDR4 ram stick which I know defiantly work but just to check have use another matched set just in case also used a couple of different known good cpu’s with same results
Any help would be much appreciated.
