Re: BN44-00301A No signs of life
NO, The ic pin 5 is hot ground, pin 4 is the vcc pin, there should be a minimum of 10.5v and likely should be around 20v on pin 4 for the ic to work. If this voltage is 0, then check if pins 4 and 5 are shorted, if there is no short then the internal startup cell is bad.
third page already, this is why I edit
Originally posted by snoptel
View Post
