Palit GTX 1050 TI memory problem?
    Hi guys,
    I have a Palit GTX 1050 Ti card with 2GB rams. (ne5105t018g1-1070f)
    The card wont give picture and if this card is the secondary I get picture from the integrated GPU but the windows is freezing after the GTX 1050 initializing.
    I tried to test with mats but I don't understand the result.
    Could anybody give some advice, how can I find the reason of this fault?
    Re: Palit GTX 1050 TI memory problem?
    never see this kind of result but it shows that all memory chips is bad.
    i will suggest to reball gpu chip
      Check that there is a 40 ohm resistor, and that 1.8 V is reaching the core .
      I had a 1050 with such errors and it did not have this resistor.
        Thank you for your suggestion but unfortunately I measured that exact values, so not is the reason of the problem.
        I'm afraid the problem is the gpu, because I tried to change the memory modules from another card and the reports of mats contains lot of errors with every modules.
        I will try to reball when the stencil arrived from China.
