Properly connecting power to the motherboard
    Hello guys,
    I have a brand new motherboard Asus TUF X570, that I just installed into chassis. Now I need to connect the power connectors properly. There is thing that confuses me and I want to double check, because I don't want to make any mistake.
    Please have a look at the attached picture. This is extract from the manual. While 24 pin connector is obvious on the right hand side, EATX12V2 and EATX12_1 are not that obvious. I pretty sure it is power supply for the CPU. Now, from the PSU there are both 4 pins and 8 pins connectors. Normally, motherboards have only one of the type, but this has two. Should I connect both connectors from the PSU, or only one? The manual says that user should not connect only 4 pin connect but either both or only 8 pins. This will be a gaming PC, so I don't know why there is an option to choose.
    I guess if the premium GPU card is used, then both connectors are needed.
    Maybe the question is stupid, but better safe than sorry.
    Thank you!
    Re: Properly connecting power to the motherboard
    This question is not stupid, if you're only using a low-power processor and have no plans on overclocking 1x CPU 8 pins on EATX12_1 is fine.
    But if you are using a higher-powered processor and have plans for overclocking it is recommended to plug in both EATX12_1 and EATX12_2
    Keep in mind: Max continuous power on one CPU 8 pin is 235w, while one CPU 4 pin is 135w
    so if you have a high-power processor or overclocked one that is near 200w it is better to put both EATX12_1 and EATX12_2.
    Edit: This might be obvious but make sure to plug the right cables, mostly on a modular PSU. switching them may have bad effects.
      Thank you Yolofolkss,
      good to know these numbers. Yes, I do have modular PSU and I connected the cables with great caution.
        I would always connect both cables, even if you currently use a low powered CPU. If you switch to a more demanding CPU later on, the cables will already be routed and you won´t have to take out the mobo again.
          +1
          If you have the cables on the PSU, might as well use them. It won't hurt anything.
