Got the motherboard free of charge because it was not powering on.
8 pin CPU power connector is not shorted, and all pins are acounted and ok.
So i put the Pentium G4400 inside presed the MBO power button and still nothing.
5VSB is present and 3.3V also.
Now the strange part.
If i press and hold power button for few seconds nothing happens but if i press it again (1 short press) after the long press the mbo starts and i see the 19 debug code on display.
I then power it off (long press).
After this procedure the motherboard starts and boots to windows, works normally.
When i shutdown, the cpu fan stays on indefinitely.
The comp will turn on normally untill i disconnect it from outlett and leave the capacitors to discharge. Then the whole procedure needs to be done again.
No bulged capacitors or leakage noticed.
Any ideas?
Any ideas?
