MSI MPG 350 Z Gaming Carbon short pch phase
    I´m trying to repair this dead Motherboard and figured out that there might be a short on PCH_PHASE or PCH_1P05_VSB. The circuit has the very low resistance to ground. its about 40 ohms.... this cant be right or?
    Motherboard is only powering for a short moment then its dead...
    [/URL][/IMG]
    [/URL][/IMG]
    I don´t know what to do next. should i inject voltage? i tried with one volt but the poer ciunsumption is only 200 milliamps...
    would appreciate to get some help cause i´m still learning....
    thx
    Re: MSI MPG 350 Z Gaming Carbon short pch phase
    Use diode mode and check. usu here the resistant is low. 40 ohm could be fine. does it start up and run ? does it boot loop ? etc willl be helpful
      40 ohms is fine for PCH, problem is elsewhere. Bulk of the issues I see on main boards is corrosion. The boards are that cheap these days I don't usually bother spending too much time on them.
