Testing and ESD Strap?
  • Nerfinator
    • Feb 2015
    • 56
    I bought 3 ESD straps, they were cheap and so I thought, well I'm going to test it. I put my multimeter to continuity, put one probe on the clamp of the ESD and touched the plate on the band side, no sound and no change on the meter. I know my meter is good and all 3 bands do this under the test.
    Am I correct in that all 3 of these straps are bad or am I missing something?
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Testing and ESD Strap?
    ESD straps have a megohm or more resistance by design.
    • Nerfinator
      • Feb 2015
      • 56
      I did not know that. How can I test to make sure it works?
      • Radio Fox
        • Jan 2010
        • 281
        Set your multimeter to a higher resistance range.
        ________________________________________________
        Invisible airwaves crackle with life
        Bright antennae bristle with the energy
        • Nerfinator
          • Feb 2015
          • 56
          Thank you, I'm pretty new to electronics and really appreciate the reply. All 3 ESDs measure at about 990 resistance.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8694
            As a scientist, the warning to you: make sure you get your units right. 990 ohms sounds too low, 990 K ohms is probably what you read.
            • chth96
              Is it possible to test small ceramic disc capacitor with analogue meter?
              by chth96
              I read EBOOK of Testing Electronic Component and found that
              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
              Is it really possible to test small ceramic disc capacitor with analogue...
              03-09-2024, 10:03 PM
            • lmcancu
              LED Strip test points and testing?
              by lmcancu
              Hi is there a guide in this forum on how to test the LED backlight TV strips? I purchased an LED tester on amazon, but I am a bit confused on the test points and how to test the individual LEDs? I took apart a RCA 43" TV Rlded4331b. Please see attached pictures. I understand that all the LEDs are in series, but on these strips I don't see any individual test points for each LED? Any tips or guides?
              Thanks in advance...
              03-20-2023, 07:52 AM
            • bauto601
              KDM 480W PSU upgrade succes! (opinions?)
              by bauto601
              Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
              A "nice" YoungYear unit? - Badcaps
              The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
              12-26-2023, 03:05 PM
            • chth96
              How Can I test PWM DM0365R?
              by chth96
              Hello
              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
              06-18-2025, 04:14 PM
              Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
              by sam_sam_sam
              I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
              https://www.aliexpress.us/item/32568...yAdapt=glo2usa
              What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
              03-30-2025, 11:05 AM
