Go Back   Badcaps Forums > Welcome to the Badcaps.net Tech Forum! > Frequently Asked Questions (No Posting)
Old 02-28-2005, 01:48 PM   #1
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default Comments on The Recapping FAQ
Here is a place for the comments to the Recapping FAQ
willawake is offline   Reply With Quote
Old 02-28-2005, 06:45 PM   #2
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
Default
Originally Posted by willawake
Solder Sucker / Soldapult (Standard Size)
This is the only part I find objectionable. I HIGHLY recommend NOT using mechanical solder suckers on motherboards! I've seen many people destroy their boards with them, typically when it recoils and impacts the board, knocking the traces off or sucking the lead port out of the PCB. If you don't have access to a pneumatic or vacuum solder sucker, use solder braid or a needle pick. The pick works best for me, I can clear a hole faster with the pick than one can with a pneumatic solder sucker.
VERY nice writeup!
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 03-01-2005, 06:33 AM   #3
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default
hmmm, i guess you are right, there is a concern. I did every board with the solder pump though and there was no probs. i am holding it flush against the board and the board is supported by the board holder. then I hit the switch which makes suction against the board and then quickly take the iron off the back of the board causing the solder to get sucked through. there is no impact against the board but maybe the pressure with the suction could damage a trace. Indeed the lead port could get sucked out.
Perhaps we can put all the methods with their pros/cons/dangers in the faq
isnt there also danger in damaging the lead port with the needle pick?
guess i have to splash out on a rework station someday.
Old 03-01-2005, 07:12 PM   #4
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
Default
VERY nice writeup!
agreed on both counts.
btw i had to rework a board from a mitek edm where a previous tech had used a soldapult.
had a short on +5 he couldnt find.
turned out to be a crumb of solder lodged between 2 pins of an ic.
there are some things a soldapult is ok for.for everything else theres ungar,weller,hakko,ect.
kc8adu is offline   Reply With Quote
Old 03-04-2005, 03:04 AM   #5
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default
ok agreed. For the people on low budgets, is a desoldering bulb the best choice then?
TC : i need to edit the "ghetto cap replacement tips" to remove reference to soldapults.
Old 03-04-2005, 07:00 AM   #6
Topcat
The Boss Stooge
Topcat's Avatar
Default
You should be able to edit the post. Let me know if you cant.
Old 03-04-2005, 04:34 PM   #7
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default
no can do. just throw it in the mods section and i will finish the recapping faq instead.
Old 05-06-2005, 05:35 AM   #8
yanz
yanz's Avatar
City & State: Dago, Bandung, Indonesia
Default
i use tc "dental pic" method and it rocks! btw i use goot/taiyo solder iron... 40w is hot enough and i found no problem.
yanz is offline   Reply With Quote
Old 01-16-2007, 12:43 PM   #9
bgavin
City & State: Orangevale, CA
Default Re: Comments on The Recapping FAQ
MCM offers a number of Tenma adjustable solder stations that are affordable to the hobbyist.
Could you experienced buys recommend what features are desireable for this level solder station? For example, I gathered that 60w + chisel tip are good. The Tenma stations are only 48w, and rated to 800F maximum.
bgavin is offline   Reply With Quote
Old 01-16-2007, 06:15 PM   #10
kc8adu
kc8adu's Avatar
My Country: U.S.A!
the bargraph and digital versions are decent.
i own one each.
the desoldering station is fragile and maintainence intensive.
my old(antique) ungar is 10x better.
Old 03-12-2007, 05:50 AM   #11
StigOE
Hi.
I'm a new member, but I have a comment about the temperature recommended for soldering the caps. I'd say 450C is way too high. When I had my soldering courses (first halves of the 90's), a rule of thumb were approx 150C above the melting point of the solder. Since normal 60/40 solder have a melting point of 177-183C, a good temperature would be about 350C. If you need as high as 450C, either you don't have a powerful enough soldering iron or a too small tip. With too high temperature it's a lot easier to damage the tracks due to disbonding. Too powerful soldering iron/too big tip/prolonged heating is no good either...
Stig
StigOE is offline   Reply With Quote
Old 03-12-2007, 10:17 AM   #12
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
I solder at 350°C and desolder at 400-450°C
Old 11-07-2007, 09:08 AM   #13
stavr0
5.5. Remove the capacitor
Gravity is your friend: Resting the board upside down, I clamp the bad cap with a needle-nose plier with an elastic band around the handle. Heat up both leads alternatively every few seconds until it falls off under the weight of the pliers.
stavr0 is offline   Reply With Quote
Old 11-07-2007, 10:16 AM   #14
severach
City & State: Michigan
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
The cheapo solder stations don't have good heat recovery so they need to run at a high temperature to have enough heat to withstand the shock of cold parts. A good solder station can do the same work much better at a much lower temperature.
What I'd like to find is a needle nose with a curved jaw and a close spring. It would resemble some of the spark plug pullers and does not need to be strong. The jaw should be silicone tipped and thin enough that I can correctly position a cap in the middle of other caps underneath a wire bundle.
severach is offline   Reply With Quote
Old 07-26-2013, 02:38 PM   #15
bobbyrae
bobbyrae's Avatar
City & State: alameda, ca
Originally Posted by StigOE View Post
Hi.
Stig
I have to agree with this. I have a Hakko Soldering station that got out of calibration for a while. I was recapping an old stereo system and I burned up a couple of pads before I realized what was going on. It had to be up around 400 degC. Of course I haven't dealt with computer motherboards yet, but I just can't see setting the temp that high because I have been able to desolder everything fine at lower temps.
bobbyrae is offline   Reply With Quote
Old 07-28-2013, 05:40 AM   #16
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
It's because motherboards often have large traces... like ground planes. and multiple layers of traces. they act as heatsinks, sucking away the heat put out by your iron. So yes, you do need to set it that high.
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 08-01-2013, 07:06 PM   #17
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Wattage is also important, to work on mother board, you will need 60 watts, you can have two soldering irons that can have the same temp, the lower wattage one will will lose it temp quickly when makes contact with the object you are trying to solder.
Badcaps.net Technical Forums © 2003 - 2023
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
