Need bios dump for hp 15-n234sl Board ID 02165, from hp site the bios is encrypted, thanks.
DA0U82MB6D0 Bios & EC Files
Re: Need Bios Dump HP 15-n234sl BID 02165
backup old bios and try thisAttached FilesIm Back... sort of...Comment
HP 15-n015st - DA0U82MB6D0 Bios & EC Files
HP 15-n015st - i5-NVidia
MB : DA0U82MB6D0
I/O : ENE KB9010QF-C4 128Kb
Bios: Winbond 25Q64FV 8MbComment
Backup old bios and try this.....Attached FilesLast edited by nbanti; 10-21-2017, 02:23 AM.Comment
Need Bios For DA0U82MB6D0 Rev D
Need Bios For :
DA0U82MB6D0
Rev D
With NVIDIA GPU
I Attach together with my dump bin file hereAttached FilesComment
Re: Need Bios For DA0U82MB6D0 Rev D
Look here but always try search before opening a new thread
https://www.badcaps.net/forum/showth...ht=DA0U82MB6D0Comment
No display can be coz of "N" number of issues in mb. You need to troubleshoot first-doesnt seems bios issue. First, check whether all the coils have voltages or not.Comment
First simptom when I received this mobo is cannot turn ON ( DC Jack LED is turned on )
After flash bios, mobo can turn ON but no display. Already tried with few version of bios but still no luck...Comment
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
Troubleshooting Attempts:
Channel: Troubleshooting Computer Displays
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by grimacelordThis laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
Motherboard model number: DA0PAMB46A1 REV: A
Secondary motherboard model number: 0PAB
SKU: 685K4UA
Serial number is: 5CD3223BJP
Recently reflashed this laptop with latest BIOS and once...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...-
Channel: BIOS & Schematic Requests!
11-06-2022, 05:22 PM -
Hi everyone,
I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
- Loading...
- No more items.
