iMac G5 PSU - no power
    Re: iMac G5 PSU - no power
    Diodes can read like that if they're across a coil. But that seems abnormally low -both- ways.
    You'll have to remove the diode to get a proper reading. Because this is a double-sided board, you can't just unsolder the legs on the underside and get a reading. The vias or thru-holes will still make contact.
    Pull it out and check it.
    105v means that they're good and current is being drawn.
    AC & DC voltages seem correct. The voltage at the cap seems low and that diode being shorted could be the reason.
    <<crosses fingers>>
    Toast
    veritas odium parit
      I hope so - be interesting to see what happens next.
      If I take that diode out and results are the same, I'm thinking the procedure for replacing it is to measure another one that looks the same and try and find a replacement? I'd have to take a good one out of circuit for an accurate reading too?
      I might pop downstairs shortly and remove the diode, if not it's a job for tomorrow - Saturday!
        On that diode, I'll bet the upper leg (cathode) is connected, via the topside trace, to the (+) leg of the mains cap. The lower leg (anode) is hooked directly to the Drain of the MOSFET.
        Now betting heavily that diode is bad.
        It is a high speed diode, so no regular diode will work here. Also, probably rated 600v and 8A.
        If it is and you go to fix it, get a new mains cap too. It's odd for that diode to go bad for no reason. Something -might- be wrong with the mains cap, even though it is a Rubycon.
        Cheers!
        I like this smiley:
        veritas odium parit
          Picture 1 in post #22 - bottom right, D7 is a small zenner - I should have made it clear which type of diode was shorted.
          Searching RS components for your suggestion reveals big diodes!
          Hmm :/
            <<takes all his money off the table>>
            You never checked the 2 legged diode next to the MOSFET mounted on the heatsink? I thought that is what you referred to in the post where you said the diode read shorted...?
            Go back and check that diode.
            On the heatsink it's - bridge rectifier - diode in question - MOSFET
            D7 is NOT a Zener. ZD9 is a Zener
            Toast
            veritas odium parit
              Diode in question test fine.
                I checked on the PSU's here. Again, I don't have anything that matches, but the circuits are fairly similar I'm sure.
                None of the diodes on my board(s) read that low. .3-.6Ω is typical with a DMM. I use an analog meter to sort out the in circuit diodes. Hate the DMM's because they show identical both ways on many that I test. The analog does not.
                A reading of .003Ω is either shorted or across a coil. Trace the circuit 1st and see if it is. Follow the paths from the diode to the next device etc. You may find a more likely suspect, or that it is across a coil/trafo etc.
                You're going to have to pull the diode off to test it. Remember these are soldered -and- firmly glued to the board. Use solder wick to get it as cleaned up as best you can and see if you can get it loose. If necessary, a replacement would still need to be a high-speed diode of possibly 1A capability.
                Can you identify for me the 3 8 legged IC's on the solder side IC1,3,5 and the 2 on top near the big cap? I'm also looking for the switcher/chopper here. These have been using a TOPSwitch device that looks like the other mounted transistors, but has 5 or 6 legs. Does this have one?
                Toast
                veritas odium parit
                  I've had a nice break from this now and gotten a few other things out of the way, so have come back to it.
                  I went on a mad raving loony session and gutted a few power bricks and ATX PSUs tonight.
                  I found the same looking diode on one, so took it off. It tested 0.620. I took the one off the iMac PSU and it also tested normally with the same value. I swapped it for the hell of it, but I don't think it's the issue.
                  IC1: (ST Logo) L6562D 9437
                  IC3 & IC5: LM393 48J Z33L
                  ICs near big cap:
                  1. TOPSwitch K433 TNY267PN 30320E
                  2. 4H2 1001DL
                    Took the heatsinks and all attached devices out of the PSU and tested - all seem to be OK. Tested a diode that I found hidden beneath it all, showed shorted in circuit, but was fine out of circuit.
                    Replaced input cap - no change.
                    Tested L6562D - seems OK
                    Tested both LM393 - they both give readings totally different from each other. Now I just need to work out which of the many different parts are the correct ones to replace them with.
                    I have a choice of:
                    LM393M/NOPB
                    LM393DRG4
                    LM393DG4
                    LM393DG
                    LM393D
                    LM393ADG4
                    LM393AD
                      Admitted defeat.
                      Bought another used power supply off of eBay, it arrived, shock horror, it's the same model!
                      Popped it in, got 5vsb trickle light showing on midplane, hit power button and the iMac worked fine (only tested 20 mins). My first ever re-cap on the iMac G5 logic board was a success!
                      I think I'll have to open up the power supply in the name of badcaps and compare it to my broken one.
                        I'm glad you acquired a working one. Recap it and enjoy!
                        I read back over this and going way back to one of my early posts, the TOPSwitch is a likely suspect. It generates the 5vsb and without that working, nothing else will. Get the datasheet for it and compare the voltages from old one to new one. It or its accompanying circuit has a failure. We were tracking the power in side of this and it seems so much time passed between that I lost track of where we were.
                        TNY263-268 link:
                        In essence, power flow is:
                        Mains > rectifier & filtering > TOPSwitch > transformer > 5vsb & 24v circuit > filtering > feedback through opto to TOPSwitch > standby power > unit startup circuit.
                        The LM393M/MX is what you're after, if you need one. That's the 8 pin SOIC package.
                        Toast
                        veritas odium parit
                          Ah I forgot to post, replaced the TOPSwitch with the same version - still nothing.
                          I'll poke around the TOPSwitch and see if it's putting out anything, then I guess we arrive at a transformer.
                          I have damaged a very small surface mount capacitor, it's lost the tinning on the end. I will try and measure this against another one and scavenge one from a dead board.
                          I'll get hold of an LM393M when I can too, then I just need to work out how to remove it. I'm about to attempt swapping a RTL8201BL package (network), so if I manage that, the LM393 should be easier.
                            Look at TOPSwitch datasheet. (Actually TinySwitch) Several basic circuits in there that should allow you to troubleshoot this psu.
                            Transformers in these are not typical failures. Haven't had one yet.
                            veritas odium parit
                              Did this ever get done seanc? Just in the back of my mind and pokes me once in a while...
                              veritas odium parit
                                I've moved house recently, I know which box it's in
                                It isn't fixed yet. Saving it for a day when I'm feeling brave.
                                The iMac in question definitely works, because I got an identical replacement PSU for it.
                                  Ok. Just that we are 5 months on from then and I thought it might have hit the bin since the replacement was working. Good to know the headache is in the future...
                                  veritas odium parit
                                    Update - I've acquired one of these in operating condition and it should be in my hands within 10 days.
                                    Hopefully, you still have yours...
                                    veritas odium parit
                                      Yes Toasty, it has survived another house move! Still have the iMac for testing too... need to get rid of it, since I have no need for it - it survived a total motherboard recap about 6 months ago.
                                        Got the PSU. Some slight variations in top layout. I don't know how different the foil side will be.
                                        What is the label on yours? Pic?
                                        This is DPS-180SB-2A REV:01
                                        veritas odium parit
                                          Sean? Helllloooooo!
                                          Also, what's the number on the edge of your board?
                                          veritas odium parit
