Request bios for HP PRODESK 600 G2 DESKTOP MINI
    i need pass unlouk
    Re: Request bios for HP PRODESK 600 G2 DESKTOP MINI
      Re: i need pass unlouk
      https://www.badcaps.net/forum/showthread.php?t=79956
        Hello, peste can you help me with this
        I have HP ProDesk 600 G2 Small Form Factor pc
        it gives 5 blinking red lights and 2 fast blinking white lights
        this is my old dump
        thank you
          Originally posted by peste View Post
          try the bios from post # 8.10
          the bios from post # 8.10 has a password, any way to remove the password?
            with hpunlocker.exe you can remove the password.
            bios checked ok, no password
              Hi Guys I need help with my HP prodesk 600 G2 mini, it gives me an error message on every boot "901-Rear chassis fan failed. There is no rear fan port on the physical motherboard. I've upgraded the cpu when this error started. The latest bios update didn't fix the error. Please help, thanks
                hi this bios has password
                nededd bios 600 g2 sff clean me and not password
                  post the original bios here and someone will delete your password..
                    Hi peste
                    I have a hp prodesk 600 G2 mini whose bios IC is damaged. I have the replacement IC, but I need the original BIOS. I have tried several posted on this forum, but they don't work. Below is the original BIOS that I managed to extract from the damaged IC.
                      Originally posted by daxx2707 View Post
                      Hi peste
                      try post #18..
                        try post #18..
                        Thanks but don't work
                          Check your CH341A.
                          Become a Badcaps supporter
                          Thanks to all supporters.
                            Originally posted by hoaca388 View Post
                            Check your CH341A.
                            I changed the software version of the CH341A and it installed fine. But, now it boots the CPU and does not give image. What could be the problem?
                              Try outputting images through other vga ports or HDMI
                                Hello when I turn on the computer I'm having blinks slow 3 times followed by 2 quick blinks.
                                According to the HP blinking code it means:
                                "The embedded controller has timed out waiting for BIOS to return from
                                memory initialization"
                                Could you help me cleaning it's BIOS please?
                                Thank you
                                  Thank you
                                  Here's your new bios file, try it and let me know.
                                  all donations are welcome,
                                    Thank you I'm going to load it tomorrow
                                    Is there a way or it is necessary to extract any information of the original BIOS such as the serial number or other Data before the modified BIOS flashing?
                                    I'm pretty noob in this field
                                    Thank you
                                      Hello hardware1,
                                      The computer is now making 5 long Beeps and 2 short, I think there is a hardware related issue...
                                        Hello. My g2 400 is bricked. Im trying to reflash bios. But there is a error [Verification error on address: 0x00000089, Device: 0x08 ]
                                        Im using ASPorgrammer and chip is MX25L128...
                                        Any sugestions will be welcome. Thanks.
                                          remove the chip from the motherboard and stick it on the programmer if you don't have an adapter.. or stick wires between the programmer and the chip. don't use the clip.. you probably don't have firm contact between the programmer and the chip..
