Vizio E55-D0 help identifying "smoked" IC on main board
    Hi folks, I have this Vizio E55-D0 that will not turn on. After some searching I found this IC smoked on the Main Board. Unfortunately the numbers are burnt off too. The IC is board number UA5.
    Can anyone help me find a number for this? I'd appreciate it.
    They call me......."threadkiller"
    Re: Vizio E55-D0 help identifying "smoked" IC on main board
    see if you can get a closer pic ..has to be in focus .
      Thanks petehall347, hopefully one of these might work?
        thats strange as i thought i could see some writing on pic 4 first lot of pics .
          I looked at a ShopJimmy picture, the printing on the top is supposed to be yellow. I can't see any of it, even with a microscope.
            looks like you need the schematic . will need resistor values etc for what connects to it as well .
              Yes...looks like lots of casualties. Has anyone had any luck finding schematics for these?
              Time to scour the webs!
                Well that went over like a lead balloon. I haven't found a thing. Vizio, release the repair information lol
                  The best picture seems to be from SJ, the ic seems to be a TI ldo, these markings look similar (this ic's pinout is different)
                    The ic might be a Ti TPS54331 or TPS54231, the tps54231 has 12Vin, 3.3vout using a 10µH coil? Check if the resistors are close for this voltage
                      The TV is put back together for now...I have 60 TVs to tear down. It's first on the list once that's done.
